Visit our LabVIEW Wiki Hardware Portal
Tags |
Jul 18 2006, 07:43 AM
Post
#1
1 more post to go! Member Posts: 9 Joined: 14-July 06 Member No.: 5583 LV:7.1 ,. ,.
Hi there!
I'm having a little problem I was wondering about. I've got a 6036e DAQ-card and I'm trying to run a sine through both outputs simultaneously. My problem is that when I'am using only one output the signal's just fine but when I configure to used both outputs I "lose" every second period. I've got the same signal levels but a sine only every second period. I'm using the traditional DAQ vi's for building the program. Tried to look at the Simul AIAO Buffer.vi in example finder but didn't get much wiser. I've probably just missed something small but since I'm new to the game I'm having trouble spotting what! /Raz
| Ad |
Post
Jul 18 2006, 10:26 AM
Post
#2
![]() I'm a LAVA, not a fighter. V I Engineering, Inc. ![]() Posts: 3851 Joined: 13-October 03 From: Michigan, USA Member No.: 181 Using LabVIEW Since:1993 LV:8.5 ,. ,.
My Blog
Please post a code snippet of what you've already tried
Jul 18 2006, 11:24 AM
Post
#3
No problems!
I'm not just looking for a solution to the problem as much as just trying to understand and learn about the different functions. cheers!
Jul 18 2006, 12:29 PM
Post
#4
My Blog
No problems! -------------------- ![]()
Jul 18 2006, 01:16 PM
Post
#5
I aware of this but it's supposed to be implemented into already existing code which has been around for a while and I've tried the mx VI's but they don't compute to well with the older stuff... The only solution I've come to so far is to run one output channel at the time... I appreciate your help and pointer though.
Thanks mate!
Jul 18 2006, 01:35 PM
Post
#6
My Blog
I aware of this but it's supposed to be implemented into already existing code which has been around for a while and I've tried the mx VI's but they don't compute to well with the older stuff... The only solution I've come to so far is to run one output channel at the time... I appreciate your help and pointer though. Thanks mate! No worries cobber! -------------------- ![]()
Jul 18 2006, 04:21 PM
Post
#7
Active Premium Member ![]() Posts: 19 Joined: 30-November 04 From: Geel, Belgium Member No.: 1135 Using LabVIEW Since:1996 LV:8.5 ,8.20 ,7.1.1
Hi Raz,
I noticed a few things about your code, first of all, the 'allow regeneration' bit is not set in the Write AO buffer (First call)? Is this intentional ? I quickly wrote a VI where DAQ input and DAQ output on two channels is done, but please note, that in this example there is no synchronisation between input and output ! If that is what you are looking for, you have to look further. This example worked here on my PC. Although not with a 6036e, but a 6110PCI board. Hope it can help You find the right solution. Success, Tom
Attached File(s)
CIT Engineering www.citengineering.com
Jul 18 2006, 04:40 PM
Post
#8
I noticed a few things about your code, first of all, the 'allow regeneration' bit is not set in the Write AO buffer (First call)? Is this intentional ? Since it's supposed to be true as default I didn't bother to create a constant for it and just assumed it would work (bad idea perhaps?!). I'm just about to call it the day but I'll have look at your code first thing tomorrow morning... Thanks a lot for Your tips and for the code. Really appreciate it!
Jul 19 2006, 07:50 AM
Post
#9
Hi Raz, I noticed a few things about your code, first of all, the 'allow regeneration' bit is not set in the Write AO buffer (First call)? Is this intentional ? I quickly wrote a VI where DAQ input and DAQ output on two channels is done, but please note, that in this example there is no synchronisation between input and output ! If that is what you are looking for, you have to look further. This example worked here on my PC. Although not with a 6036e, but a 6110PCI board. Hope it can help You find the right solution. Success, Tom Hi Tom! I tried Your idea this morning, not bothring about synchronisation between in- and output... I experienced the same behaviour as before. I'll try some different setup but I'll probably end up running one output at the time. That way I know it works perfect. As I said before, I really appreciate Your help and efforts. This is still the best way of learning for me, some good ol' trial and error! Thanks Tom! /Raz
Jul 19 2006, 10:57 AM
Post
#10
Here's another question maybe someone can answer!
I'm injecting a sine on one of the DAQ-outputs (got a 6036e) and configure 4 inputs for different readings of the sine through different lines (i.e. sound channels). I'm just wondering why I get a subdued signal (noise?) on the other channels when I've just connected one of the four channels. It's not a crucial thing for my readings, just wondering if someone's got an explanation. /Raz
Jul 19 2006, 04:16 PM
Post
#11
Extremely Active Premium Member ![]() Posts: 266 Joined: 1-December 04 Member No.: 1144 Using LabVIEW Since:1992 LV:8.5 ,7.1.1 ,.
Hi Raz:
Try shorting the unused inputs. Very high input impedance on the inputs, a little bit of capacitive coupling between the different channels in the multiplexor, and bingo, your signal shows up as noise on the unused channels. Even if it doesn't cause any problems, a good idea to short the unused channels. best luck, Louis
Jul 19 2006, 10:48 PM
Post
#12
![]() Extremely Active Member Posts: 529 Joined: 2-August 05 Member No.: 2680 Using LabVIEW Since:1996 LV:8.5.1 ,8.6 ,.
Hi there! I'm having a little problem I was wondering about. I've got a 6036e DAQ-card and I'm trying to run a sine through both outputs simultaneously. My problem is that when I'am using only one output the signal's just fine but when I configure to used both outputs I "lose" every second period. I've got the same signal levels but a sine only every second period. I'm using the traditional DAQ vi's for building the program. Tried to look at the Simul AIAO Buffer.vi in example finder but didn't get much wiser. I've probably just missed something small but since I'm new to the game I'm having trouble spotting what! /Raz Its been a while since I played with DAQ but as far as I can remember, even though you have 2 AO channels they are not 'independent'. You can't run each one with different frequencies, since the DAQ card has only one FIFO. I think you are seeing this when trying to output both chans. You can set both to use the same frequency, and then they might work. See: Can I Individually Control Each Analog Output Channel on my E-Series Board? I have found the DAQmx performance to be much better with the 6036 and multiple AO's, since the driver is multi-threaded, it can switch between DAQ tasks without 'freezing' in-between. Cheers, Neville.
| Time is now: 8th January 2009 - 07:23 PM |
