Visit our LabVIEW Wiki Apple article
May 16 2006, 06:36 PM
Post
#1
Active Member Posts: 21 Joined: 21-March 06 From: Paris Member No.: 4507 Using LabVIEW Since:2004 LV:8.20 ,. ,.
I'm trying to use DAQ S 6143 and M 6224 simultaneously using DAQmx base. I should admit I'm a little bit frustrated since I didn't managed to do anything !... : - Using RTSI cable to share sample clock using daqmx base export signal vi, nothing works. - Using "daqmx base start trigger (analog edge)" to do triggering (start an acquisition when an analog input cross a level) on a single device, nothing works. (example below). Could somebody have any successful experience to share in the field of triggering/synchronizing on mac os x or should I abandon all my hopes...? For now, I'll go to bed ! Thanks Boris
Attached File(s)
Tags
| Ad |
Post
Tags
May 18 2006, 01:02 PM
Post
#2
![]() More Active Member Posts: 37 Joined: 19-October 04 Member No.: 853 Using LabVIEW Since:1999 LV:8.20 ,7.1.1 ,7.0
have you tried to test your board with more simple aquisition task ?
-------------------- Pour les francophones --> astuces vidéo sur Mac OS X
Tags
May 18 2006, 01:46 PM
Post
#3
Hi Tibras
have you tried to test your board with more simple aquisition task ? Yes, I'm using simple acquisition tasks for more than one year on both boards, but without hardware triggering. Now I have to synchronize acquisition between the two cards and that's why I get to try sample clock sharing with RTSI bus. It didn't work so I tried using triggering which didn't work too The fact that RTSI doesn't work is not surprising for me (since it's written here : http://zone.ni.com/devzone/conceptd.nsf/we...256FB1007227EC). The fact that triggering doesn't work is more surprising. Did you ever tried synchronising or triggering with mac os x ? Boris This post has been edited by tibobo: May 18 2006, 01:48 PM Tags
May 18 2006, 02:32 PM
Post
#4
Did you ever tried synchronising or triggering with mac os x ? unfortunately not just continious analog acquisition… in couple weeks, I've no time for test but later… I keep you in touch… This post has been edited by ptit bras: May 18 2006, 02:33 PM -------------------- Pour les francophones --> astuces vidéo sur Mac OS X
Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
3 | godfather | 1390 | 29th June 2004 - 10:34 AM Last post by: godfather |
1 | skfink | 953 | 27th July 2005 - 01:45 PM Last post by: m3nth |
0 | tueddelmeister | 872 | 4th October 2005 - 08:12 AM Last post by: tueddelmeister |
1 | stumpjumper | 1064 | 16th October 2005 - 10:38 PM Last post by: Wolfram |
| Time is now: 7th October 2008 - 12:26 AM |
