Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Mar 22 2006, 06:51 PM
Post
#1
![]() Extremely Active Member Posts: 301 Joined: 6-March 06 Member No.: 4344 Using LabVIEW Since:1997 LV:7.1.1 ,. ,.
Does anybody know why condional probes are available for U32, I32, and Double wires, but not for other data types? Does this limitation still exist in LV8?
Thanks, Gary
| Ad |
Post
Mar 22 2006, 07:36 PM
Post
#2
![]() Very Active V I Engineering, Inc. ![]() Posts: 131 Joined: 8-February 06 Member No.: 4078 Using LabVIEW Since:2002 LV:8.20 ,8.0 ,7.1
Hi Gary,
While I'm not sure on why conditional probes are only available for certain types -- I'll tell you that nothing has changed in LV8. Of course, there's a few more conditional probes for non-numerics (which are in LabVIEW 7, too) -- Strings, Booleans, Error Clusters. Anytime I want a conditional probe on a numeric which isn't I32/U32/DBL I normally split the wire and convert the offshoot to DBL and then make that wire go to a structure (which I don't use) and use a conditional probe on that one new DBL wire. That way, I'm not messing with the original wire's data type, but of course, it's a bit quirky...
Mar 22 2006, 07:40 PM
Post
#3
QUOTE Anytime I want a conditional probe on a numeric which isn't I32/U32/DBL I normally split the wire and convert the offshoot to DBL and then make that wire go to a structure (which I don't use) and use a conditional probe on that one new DBL wire. Thanks, That's what I've been doing too. It would just be nice to not have to clutter up the diagram like that... Gary
Mar 23 2006, 02:16 AM
Post
#4
![]() Confucius say: Crowded elevator always smell different to midget Admin ![]() Posts: 2402 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
Does anybody know why condional probes are available for U32, I32, and Double wires, but not for other data types? Does this limitation still exist in LV8? Am I missing something? Why not create a custom conditional with any datatype you want?
Thanks, Gary -------------------- Thank You
Michael Aivaliotis - Follow me on Twitter - My Personal Blog Search the LabVIEW Web - Build the LabVIEW Web - Got VIPM? ![]()
Mar 23 2006, 04:04 AM
Post
#5
Why not create a custom conditional with any datatype you want? You know, I've never thought of that -- Making a custom probe gives you a boolean out to allow for a conditional probe style. Thanks Michael!
Mar 23 2006, 01:07 PM
Post
#6
You know, I've never thought of that -- Making a custom probe gives you a boolean out to allow for a conditional probe style. Jeff, you don't even have to do it that way. Maybe this was what Michael was refering to... There's a probes directory in vi.lib where the conditional probes live as vi's. Modify one of them (say the I32 to be an I16), and then select it as your custom probe. Now you have a conditional I16 probe. No need to use a boolean conditional probe on another custom probe (if I'm understanding you correctly). Gary This post has been edited by Gary Rubin: Mar 23 2006, 01:07 PM
Mar 24 2006, 01:56 AM
Post
#7
Instant Human, just add coffee Premium Member ![]() Posts: 889 Joined: 31-January 03 From: Waterford, CT USA Member No.: 45 Using LabVIEW Since:1992 LV:8.2.1 ,7.1 ,8.0.1
Am I missing something? Why not create a custom conditional with any datatype you want? You know, I've never thought of that -- Making a custom probe gives you a boolean out to allow for a conditional probe style. Thanks Michael! I started to post this yesterday, but stopped. Rather than reinvent another custom, why not go over to the OpenG website and get the Universal Probe and modify it slightly to make it conditional like you want? One size fits all. -------------------- ************************************************************* "Always listen to the experts, they'll tell you what can't be done, and why. Then go do it." ~The Notebooks of Lazarus Long (by Robert Heinlein) *************************************************************
| Time is now: 8th January 2009 - 07:31 PM |
