Tags
2 Pages V   1 2 >
> Typedef enum CONSTANT changes during execution, Status: Fixed in 8.0.1
labviewman
post Feb 21 2006, 01:55 AM
Post #1
3 more posts to go!
Member
Using LabVIEW Since:1995
LV:8.5.1 ,. ,.
United States Nothing Selected Nothing Selected
I have a simple .vi that uses a queued state machine using typedef enum constants. A very common technique in a state machine.
What I didn't expect was the typedef enum constant (yes, a constant!) to change during execution. Quite a serious bug.
This was originally LV7.0 code, converted it to LV7.1 but the problem exists. I have not tried LV8.0 (haven't even taken it out of shrink wrap yet).
NI is looking into this, issue #7105073.
Todd
Attached File(s)
Attached File  type_def_enum_constant_changes.zip ( 43.04K ) Number of downloads: 209
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
yonatan.tidhar
post Feb 21 2006, 05:46 AM
Post #2
Active
Member
Using LabVIEW Since:2001
LV:8.5 ,. ,.
Israel Nothing Selected Nothing Selected
I can see this too (7.1) and try few things - the only thing that help was to disconnect the constant from the typedef question.gif
so its look like the problem is in the typedef.
Tags
+Quote Post
labviewman
post Feb 21 2006, 07:10 AM
Post #3
3 more posts to go!
Member
LV:8.5.1 ,. ,.
I tried that before and it didn't work. I even re-created the type-def completely, and it didn't work.
What did work was to replace the 'enqueue element' at the problem location in the code.
Watch how tnhe constant changes during execution...then changes back when the program stops!
It didn't take long to track down this problem since the code from this was taken is quite simple.
QUOTE (labviewman @ Feb 20 2006, 09:55 PM) *
Todd
Tags
+Quote Post
crelf
post Feb 22 2006, 01:24 AM
Post #4
I'm a LAVA, not a fighter.
V I Engineering, Inc.
Using LabVIEW Since:1993
LV:8.5 ,. ,.
Australia United States Nothing Selected My Blog
Confirmed on LabVIEW 8.0 as well - as suggested, disconnecting it from the typedef fixes it...
Tags
+Quote Post
labviewman
post Feb 22 2006, 03:47 AM
Post #5
3 more posts to go!
Member
LV:8.5.1 ,. ,.
A big question is why is this happening in the first place? Can we ever trust queued state machines again using typedef enums?
NI is looking into it; I will provide and update here when I get an answer.
Tags
+Quote Post
Aitor Solar
post Feb 23 2006, 04:54 PM
Post #6
Member
Using LabVIEW Since:2000
LV:8.5 ,8.20 ,7.1.1
Spain spn_Madrid Nothing Selected
I suspect is a casting problem, something usual with enums. In fact, if you explicitly typecast the constant to U16 the problem dissapears... So in some step LabVIEW doesn't know what representation is that control.
Unfortunately I have no more time today, tomorrow I'll check it more deeply.
Saludos,
Aitor
Tags
+Quote Post
neB
post Feb 23 2006, 05:08 PM
Post #7
Certified Kool-Aid Kid
Premium Member
Using LabVIEW Since:1998
LV:7.1 ,. ,.
United States Germany Nothing Selected
QUOTE (Entropy @ Feb 23 2006, 11:54 AM) *
Saludos,
Aitor
I took a quick peek at this the other day and it reminds me of a similar "form" of bug that involved a cluster. It looks like the optimization and buffer re-use logic is out of whack. The original buffer holding the constant is being updated instead of copied. Code changes that force execution order can help. Looks like constant folding is out of control.
Just my quick guess,
Ben
Tags
+Quote Post
AnalogKid2Digita...
post Feb 23 2006, 09:46 PM
Post #8
Member
LV:8.20 ,. ,.
Off topic, but Ben- just one more post to go. thumbup1.gif Sorry, no stars rolleyes.gif
‘It’s the questions that drive us'
Tags
+Quote Post
Aitor Solar
post Feb 24 2006, 08:32 AM
Post #9
Member
LV:8.5 ,8.20 ,7.1.1
QUOTE (Ben @ Feb 23 2006, 06:08 PM) *
Yes, that's true. And I think the problem is located in the queue creation. If you just rewire it or wire another copy of the enum constant, the problem solves. So I suspect that first constant set to "key id" is corrupt and, from that point, LabVIEW loses a valid reference to the object and what the heck it is.
In fact, if we knew how to reproduce this, it would be really interesting to change constants in run time wink.gif
Saludos,
Aitor
Tags
+Quote Post
neB
post Feb 24 2006, 12:02 PM
Post #10
Premium Member
LV:7.1 ,. ,.
QUOTE (Entropy @ Feb 24 2006, 03:32 AM) *
Saludos,
Aitor
Paraphrasing a posting by Rolf years ago....
OT > AK2DM
Ben
Tags
+Quote Post
Yair
post Feb 24 2006, 12:54 PM
Post #11
Extwemely Active
Premium Member
Using LabVIEW Since:2003
LV:7.0 ,7.1 ,.
QUOTE (Ben @ Feb 24 2006, 02:02 PM) *
OT > AK2DM
Ben
I know that I said that there are no stars here, but it was slightly changed since then. If you really want to give stars, each thread has a Rating button hiding on top, which rates the entire thread.
Personally, I find the NI forums much easier to use than the LAVA forums (even though LAVA has a significantly larger number of features). This is mostly because the NI forums have a much cleaner design (simple colors, mostly text) and because there it is easier to follow when things get posted (since LAVA is influenced by your logins and not by whether you actually read the posts). As long as LAVA doesn't have too much activity, though, it's not too much to handle. Thanks, Michael and team.
More than meets the eye...
Tags
+Quote Post
Aitor Solar
post Feb 24 2006, 12:57 PM
Post #12
Member
LV:8.5 ,8.20 ,7.1.1
QUOTE (Ben @ Feb 24 2006, 01:02 PM) *
Not necessarily the same VI, but between them. Here the .ctl is in fact working as a external variable, in a very simple manner. Maybe this works between different runtimes too, all accessing the same type definition. Well, OK, probably not rolleyes.gif.
Saludos,
Aitor
Tags
+Quote Post
crelf
post Feb 24 2006, 01:33 PM
Post #13
LV:8.5 ,. ,.
QUOTE (Entropy @ Feb 24 2006, 06:32 PM) *
Tags
+Quote Post
labviewman
post Mar 3 2006, 12:17 PM
Post #14
3 more posts to go!
Member
LV:8.5.1 ,. ,.
Here is NI's response:
R&D have identified your issue as a bug and it will be fixed in the next release/patch for LabVIEW. Please let me know if you have any other questions about this issue.
Tags
+Quote Post
neB
post Mar 3 2006, 02:09 PM
Post #15
Premium Member
LV:7.1 ,. ,.
QUOTE (labviewman @ Mar 3 2006, 07:17 AM) *
I have added this thread to the official NI BUg List that can be found here.
http://forums.ni.com/ni/board/message?boar...message.id=1882
For those of you that do not frequent the NI Developer Exchange I want to make sure you are aware that the NI Bug List is now Official as I mention here. (See reply #20).
http://forums.ni.com/ni/board/message?boar...message.id=1698
The Official NI Bug list should NOT be viewed as competition for the LAVA Bug List. It should be viewed as a compliment of same.
"Keep them bug and letters coming!"
Ben
Tags
+Quote Post
