Tags
> LV shut down caused by "Formula"
alphaone
post Dec 8 2005, 02:23 AM
Post #1
More Active
Member
LV:8.0
China Nothing Selected Nothing Selected My Blog
Hi, I input a "Numeric" with Unit of "Hz", and output to a "Numeric indicator",the fatal error happened when running. Check the following figures.
And I want use the Numeric control with Unit input into the "Formular Node", but it can't do! Using the Unit would be couraged??
Attached thumbnail(s)
Attached image(s)
Attached Image Attached Image
Attached File(s)
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
didierj
post Dec 8 2005, 07:43 AM
Post #2
Member
Using LabVIEW Since:1997
LV:7.1.1 ,6.1 ,.
Switzerland France Nothing Selected
What a strange example...
On my computer, when I start this vi, it never stops and raises the cpu load to 100%. In the meantime I read the whole Info-LV-digest, and now while I write this post the vi is still running and my cpu tells 100% load. Most strange is although the cpu load is at 100%, I don't seem to have any limitation in speed for the other apps.
...Update: after 25(!!!) Minutes I finally also got your error. thumbdown.gif
Tags
+Quote Post
alphaone
post Dec 8 2005, 08:35 AM
Post #3
More Active
Member
LV:8.0
QUOTE (didierj @ Dec 8 2005, 03:43 PM) *
Maybe, this is a solution that use "Type Case" to transfered.
Attached image(s)
Attached File(s)
Tags
+Quote Post
DredPirate
post Dec 8 2005, 06:19 PM
Post #4
More Active
Member
LV:7.1.1
United States Nothing Selected Nothing Selected
And here is another reason not to use express VIs or LabVIEW unit labels.
Had to kill LabVIEW throwpc.gif to stop this VI.
Tags
+Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts   3 guy 7663 21st May 2003 - 09:59 PM
Last post by: Mark Hanning-Lee
No New Posts   5 JackHamilton 7253 12th August 2005 - 07:27 AM
Last post by: rolfk
No New Posts   1 seckley 5444 20th December 2002 - 04:36 AM
Last post by: Michael_Aivaliotis
No New Posts   0 Michael_Aivaliotis 4871 20th May 2003 - 09:10 PM
Time is now: 12th October 2008 - 09:01 AM
