Tags
> non-sequential values Slider Bug?
WMassey
post Nov 14 2005, 04:43 PM
Post #1
Member
LV:7.1.1
United States Nothing Selected Nothing Selected
I have an I32 vertical slider control (attached) which has non-sequential values running from -2 to 8 but lacking a value for zero. The control produces the correct values and, if you ignore the placement of the slider on the scale, looks right. But the slider itself, in most cases, never aligns properly with the scale. The slider does not move in even increments from value to value. I suspect this might be a bug.
Can anyone else confirm this behavior on their system? Does it work properly in version 8?
Attached File(s)
Warren Massey
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
jpdrolet
post Nov 14 2005, 06:14 PM
Post #2
Premium Member
LV:7.1.1 ,. ,.
Canada ca_quebec Canada
QUOTE (WMassey @ Nov 14 2005, 11:43 AM) *
I confirm. The behavior is correct if you set the type to double. You may also try to use arbitrary scale markers.
A diagram is worth a thousand lines.
www.avensys.ca
Tags
+Quote Post
WMassey
post Nov 14 2005, 07:17 PM
Post #3
Member
LV:7.1.1
QUOTE (jpdrolet @ Nov 14 2005, 10:14 AM) *
I confirm.
Thanks! I've turned it in to NI to see what they have to say.
QUOTE
And thanks for the convenient workaround! I had not found that.
Just a quick followup...
NI has confirmed that this is a bug in 7.1 but 8.0 is OK.
This post has been edited by WMassey: Nov 14 2005, 08:44 PM
Warren Massey
Tags
+Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts   1 JohnRH 2492 9th April 2004 - 06:50 PM
Last post by: Michael_Aivaliotis
No New Posts   2 donroth 2599 5th September 2003 - 02:01 PM
Last post by: donroth
No New Posts   8 Paul 1598 2nd July 2004 - 02:06 PM
Last post by: Paul
No New Posts   1 asic 997 5th July 2004 - 06:36 PM
Last post by: Khalid Ansari
Time is now: 10th October 2008 - 11:29 PM
