Tags
> Multiple LabVIEW Versions and TestStand on 1 PC, What order do I install ?
CRoebuck
post Nov 10 2005, 10:17 AM
Post #1
Active
Validating
Using LabVIEW Since:1998
LV:8.20 ,7.1 ,8.0.1
United Kingdom Nothing Selected Nothing Selected
Hi everyone
I wish to run LabVIEW 6.1 and 7.1 on the same machine, I also want to use TestStand 3.0 with my LabVIEW 7.1 vi's.
I want all my toolkits (Database, SDTK, Internet Developers) to be available to both versions of LabVIEW.
I have a clean machine and the CD's at the ready !
What order should I install things in to get what I want ?
I was thinking LabVIEW 6.1 >>> LabVIEW 7.1 >> Toolkits >> TestStand 3.0
Any better ideas or suggestions on how I can make this as painless as possible ?
Best Regard
Chris
Chris Roebuck
CLD
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
brian175
post Nov 10 2005, 02:20 PM
Post #2
Member
LV:7.0
QUOTE (CRoebuck @ Nov 10 2005, 06:17 AM) *
Hi Chuck,
I haven't used TestStand so someone else will have to help with that. The problem with some of NI's toolkits is that the installer will only allow it to be installed once. This is a real pain, so if the toolkit doesn't allow multiple installations you will have to install to the earlier version and then manually copy to the newer. So your order will look like this:
LV 6.1 >> Toolkits(CD) >> Mass Compile >> LabVIEW 7.1 >> Toolkits(CD or manual copy) >> Mass Compile
I know for sure that the Internet Toolkit will only install once and that you will need to manually copy to install in the second time. Since you are starting out fresh you could install LabVIEW 6.1 and then make a copy of the LabVIEW 6.1 directory. Next install the toolkits you want to the original LabVIEW directory and then compare it against the copy of the virgin LabIVEW install. The difference would be the files to copy to the new LabVIEW install. Don't forget to mass compile, many of NI's toolkits are created in older versions of LabVIEW and are not recompiled for the newer versions.
If you don't have the ability to compare directories, then be sure to check these for the Internet Toolkit:
...\LabVIEW 6.1\vi.lib\addons\internet <=copy entire directory
...\LabVIEW 6.1\examples\internet <=copy entire directory
...\LabVIEW 6.1\help\internet.hlp
...\LabVIEW 6.1\help\internet.txt
...\LabVIEW 6.1\project\internet <=copy entire directory
...\LabVIEW 6.1\project\internet.txt
...\LabVIEW 6.1\www <=copy entire directory
And since you now have multiple version of LabVIEW you may want to try the DataAct Version Chooser for LabVIEW.
Good luck,
Brian
Brian Gangloff
DataAct Incorporated - NI Alliance Member
http://store.dataact.com/
Tags
+Quote Post
Time is now: 8th January 2009 - 07:58 PM
