Please post topics into this forum that relate to specific features introduced in LabVIEW 8.x.x. The post will be moved to the appropriate forum if it does not meet this requirement. Your post may also be moved if it's deemed that it would fit better in another forum regardless. For example: LabVIEW OOP topics should go to the GOOP forum.
Oct 19 2005, 12:20 AM
Post
#1
Changing the world, one VI at a time. Premium Member ![]() Posts: 1665 Joined: 22-October 02 From: San Francisco, CA Member No.: 17 Using LabVIEW Since:1995 LV:8.2.1 ,8.5 ,7.1.1
My Blog
My Gallery
This can be activated after the expiry to a full version upon purchase.
Have fun -------------------- Tags
| Ad |
Post
Tags
Oct 20 2005, 05:56 PM
Post
#2
![]() Active Member Posts: 13 Joined: 20-October 05 From: Grevenbroich, Germany Member No.: 3293 Using LabVIEW Since:1993 LV:7.1.1 ,8.5 ,.
The file has gone.
Otherwise I'll have to wait for my SSP update in November (yes, that late in Germany..). What a pity. Thomas Tags
Oct 20 2005, 06:13 PM
Post
#3
Very Active Member Posts: 164 Joined: 18-March 04 From: Canada Member No.: 311 Using LabVIEW Since:1995 LV:8.20 ,7.1.1 ,.
The file has gone. Otherwise I'll have to wait for my SSP update in November (yes, that late in Germany..). What a pity. Thomas There's a readme in there which says the following: QUOTE LabVIEW 8 is no longer available at this location. To obtain the file please visit: http://digital.ni.com/demo.nsf/websearch/1...&node=157200_US -Khalid Tags
Oct 20 2005, 06:17 PM
Post
#4
2 more posts to go! Member Posts: 8 Joined: 23-September 05 From: Pacific Northwest Member No.: 3053 LV:8.0
Used the Readme link above.
Answer a few questions and download starts. Downloading it now... Tags
Oct 20 2005, 07:10 PM
Post
#5
Thanks a lot for pointing me to the README.
Well, unfortunately my first try to get the file via http failed after 250MB (of a 450MB total size) With ftp I could resume from there - http urges me to start from the beginning. My apologies, NI admins, for raising the traffic level by reloading the first 250 megs. X-ing fingers for the 2nd try Thomas Tags
Oct 20 2005, 09:27 PM
Post
#6
More Active Member Posts: 37 Joined: 3-April 05 Member No.: 1965 LV:7.1
Anyone trying to download a file this big using basic Windows IE download feature is likely to be extremely disappointed. Most browsers can't not, by default, handle a file download this large. I recommend getting a file download tool. I like to use something called "Star Downloader", personally, which has a free version.
Tags
Oct 21 2005, 03:26 AM
Post
#7
My Blog
My Gallery
They're so tricky. Here is the new link:
http://labview8.ni.com/evaluation/labview/pc/labview_80.exe -------------------- Tags
Oct 21 2005, 03:33 AM
Post
#8
![]() Confucius say, Man with tight trousers is pressing his luck. Admin ![]() Posts: 2323 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
They're so tricky. Here is the new link: http://labview8.ni.com/evaluation/labview/pc/labview_80.exe I've updated all the links to Jim's new posted location. It should work now. BTW, I used Firefox default download system and it worked the first time, perfectly. -------------------- Tags
Oct 21 2005, 08:33 AM
Post
#9
I've updated all the links to Jim's new posted location. It should work now. BTW, I used Firefox default download system and it worked the first time, perfectly. I've been successful with Firefox, too. Right-click labview_80.exe -> Save it to a location with 500 megs free. Thanks Jim & Michael! Thomas Tags
Oct 21 2005, 08:39 AM
Post
#10
Extremely Active Premium Member ![]() Posts: 978 Joined: 9-April 04 From: Rotterdam Member No.: 349 Using LabVIEW Since:1992 LV:8.5.1 ,8.2.1 ,7.1.1
I've updated all the links to Jim's new posted location. It should work now. BTW, I used Firefox default download system and it worked the first time, perfectly. Yep, Firefox download worked well too. Wouldn't ever have tried the same with IE though. Even 50MB files used to be a one out of ten chance to work. Rolf Kalbermatter Tags
Oct 21 2005, 11:24 AM
Post
#11
![]() Extwemely Active Premium Member ![]() Posts: 1598 Joined: 23-January 05 From: Here Member No.: 1431 Using LabVIEW Since:2003 LV:7.0 ,7.1 ,.
Yep, Firefox download worked well too. Wouldn't ever have tried the same with IE though. Even 50MB files used to be a one out of ten chance to work. Rolf Kalbermatter I managed to download 130 MB of the file using IE (which varied between 8-80 KB\s) before I experienced a local power outage, which caused my internet connection to die. I also think I remember downloading other files which were several hundered MBs using IE (I don't remember which files, though), so either I'm the one in ten, or IE works OK now. After the power was back I restarted with DAP and got it all at around 200 KB\s (DAP simulates several users downloading at the same time, allowing you to get better speed). -------------------- More than meets the eye...
Tags
Oct 22 2005, 07:04 AM
Post
#12
Enough LAVA to be dangerous Member Posts: 4 Joined: 10-October 04 Member No.: 771 LV:8.0
I've been successful with Firefox, too. Right-click labview_80.exe -> Save it to a location with 500 megs free. Thanks Jim & Michael! Thomas thanks, ftp server been closed, Tags
Nov 7 2005, 11:26 PM
Post
#13
Just because a file completes download doesn't mean all the bytes in it are correctly downloaded. Its surprising how often this is true. To be safe, download a checking utility called "md5sum.exe" here:
http://www.etree.org/md5com.html#download Run "md5sum.exe labview_80.exe" and the program should spit out this checksum: 42950520eb90d3908c74e97461480988 Of course, this is my result. If they change the file on the server, the checksum would change. Perhaps someone here can give me a "Hey I got that too!" It only takes a couple minutes to do this and is far easier than dealing with the ill-effects of a slightly warped download. Tags
Nov 9 2005, 08:27 PM
Post
#14
I've come back for more. NI ![]() Posts: 2 Joined: 9-November 05 From: Austin, TX Member No.: 3456 LV:8.0
Howdy! I lead the Web Systems team at NI; we're the ones making the file available electronically. Saw this discussion and wanted to chime in with some helpful notes...
1. The MD5 checksum of the labview_80.exe file is indeed 42950520eb90d3908c74e97461480988; we've added a labview_80.exe.md5 file with this sum in it to the site for your convenience. 2. The file is definitely still available via FTP, you can use ftp://labview8.ni.com/evaluation/labview/pc/labview_80.exe - we have it available via HTTP as well for people that have problems FTPing at http://labview8.ni.com/evaluation/labview/pc/labview_80.exe. We do recommend using FTP. When you fill out the page at http://digital.ni.com/demo.nsf/websearch/1...&node=157200_US (and please do take a sec to do this, we'd love to hear more about you before you download) it will try to open the download via FTP automatically but provides a http:// link as a backup. 3. Anyone having trouble downloading LV8, please do report it to us at webmaster@ni.com or by going to https://sine.ni.com/apps/utf8/nicc.call_me?p_form_id=5. Suggestions on how to improve your software downloading experience are also welcome! Thanks, Ernest Mueller National Instruments Tags
Nov 14 2005, 11:40 PM
Post
#15
![]() More Active Member Posts: 35 Joined: 27-August 04 From: Baltimore, MD Member No.: 632 LV:7.1
Howdy! I lead the Web Systems team at NI; we're the ones making the file available electronically. Saw this discussion and wanted to chime in with some helpful notes... SNIP Hi, I currently have LabVIEW 7.1 installed in my lab, but I'd really like to move over to LabVIEW 8. What are the implications of downloading and running the LV8 download that is being linked in this thread? Ie, do I need to purchase new licenses, or can I re-use my old ones, etc? Thanks. Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | ||
3 | guy | 7663 | 21st May 2003 - 09:59 PM Last post by: Mark Hanning-Lee |
5 | JackHamilton | 7253 | 12th August 2005 - 07:27 AM Last post by: rolfk |
