Check out our User Interface Code Repository Files or visit the LabVIEW Wiki User Interface Portal
Tags |
Mar 12 2004, 12:30 PM
Post
#1
More Active Member Posts: 45 Joined: 4-March 04 Member No.: 292 LV:7.0 |
I'm doing a custom control in which it would be useful if I could add code. I know we never had this ability before 7, but when the need arose I had a flash back to when I first started to play with Labview 7 and at the time I had a "wow" moment where I thought I could actually do this.
Am I going mad? -------------------- Dr. Craig Graham, Software Engineer
Advanced Analysis and Integration Limited, UK.
| Ad |
Post
Mar 12 2004, 03:07 PM
Post
#2
![]() Confucius say: Crowded elevator always smell different to midget Admin ![]() Posts: 2367 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
I guess this should be a wish-list item. As fas I'm aware, this is not possible yet. I guess the closest thing would be to create a sub-vi with the code and feed-in a ctrl reference to the control of interest. Would this work for you? What exactly do you want to do with the custom code that can't already be done with conventional methods?
Mar 12 2004, 03:56 PM
Post
#3
That's what I've done, but it's irritating. I have to feed in a reference to the picture ring, a reference to a control boolean hidden next to the picture and a reference to the stop button and just launch the thing off to one side.
I wanted an "animated boolean"- static image when false and an animated image when true. Easy enough with a picture ring, but it would have been nice to be able to feed a boolean into a custom control and have a loop in the custom control cycling through the images in the true state. Always annoying when my memory starts playing tricks. -------------------- Dr. Craig Graham, Software Engineer
Mar 12 2004, 04:51 PM
Post
#4
My Blog
My Gallery
Oh, now I know what feature you might have seen.
This comes back to "playing" with graphics programs. You can now add animated GIF's to your controls. This will do exactly what you want. No special thing you have to do just generate 2 different animated GIF's in your graphics package and then place it in the 2 different states. --------------------
Mar 16 2004, 07:49 AM
Post
#5
Now I know what my "wow" memory was- it was the ability to add code to custom probes!
So I guess the ability to add code to custom controls isn't a huge distance away. -------------------- Dr. Craig Graham, Software Engineer
Apr 21 2004, 12:41 PM
Post
#6
<customize this text> Premium Member ![]() Posts: 1012 Joined: 9-April 04 From: Rotterdam Member No.: 349 Using LabVIEW Since:1992 LV:8.5.1 ,8.2.1 ,7.1.1
QUOTE (CraigGraham @ Mar 16 2004, 02:49 AM) So I guess the ability to add code to custom controls isn't a huge distance away. Another idea might be to use sub panels for this. Create the control as a subVI with all the code you might feel necessary and allow some sort of communication to the main VI for instance through user registered events or queues. Then whenever you need the control insert it with a simple call into a sub panel control. Rolf Kalbermatter
| Time is now: 1st December 2008 - 08:46 PM |
