> Related links
Check out our User Interface Code Repository Files or visit the LabVIEW Wiki User Interface Portal
Tags
> Menu Item "page Setup", how to invoke it programmaticaly
didierj
post Mar 2 2004, 07:35 AM
Post #1
Member
Using LabVIEW Since:1997
LV:7.1.1 ,6.1 ,.
Switzerland France Nothing Selected
In the standard menu there is an "application item" that is named "page setup...".
Because I have to build my application in a third language (that might not be the system language) I should either:
- be able to change the the item name of this "application item" or,
- create a "custom item" and run the "page setup"-panel programmaticaly.
Does anyone know how to implement one of the two possibilities?
Thanks,
Didier
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Randall Thurman
post Mar 2 2004, 03:18 PM
Post #2
More Active
Member
LV:7.1
United States Nothing Selected Nothing Selected
You may accomplish the actions accessed by the page setup programmatically. Place a property node on the wiring diagram, this is found in the application control pallet. Right click on the control and make the following selection select class>>vi server>>vi.
After this is accomplished right click on the property node again and select Properties>>Printing>> this should provide you the control you need. These properties may be set to read or write depending on your applications.
Hope this helps.
Randall
Tags
+Quote Post
didierj
post Mar 3 2004, 07:37 AM
Post #3
Member
LV:7.1.1 ,6.1 ,.
I know the property node very well, but on LabVIEW 6.1 there is no such property on vi class.
Didier
Tags
+Quote Post
Michael_Aivaliot...
post Mar 4 2004, 12:04 AM
Post #4
Group Icon
Admin
Using LabVIEW Since:1994
LV:8.5 ,8.2.1 ,7.1.1
QUOTE (didierj @ Mar 2 2004, 02:35 AM)
What Language is this concerning? LabVIEW will use French, German or Japanese menus if you use the application builder for that language.
The other alternative as Randall mentioned is only available in LV7.0... sorry.
Tags
+Quote Post
didierj
post Mar 9 2004, 06:44 AM
Post #5
Member
LV:7.1.1 ,6.1 ,.
I see, I'll probably have to revise my source or upgrade...
Thanks for the replies.
Didier
Tags
+Quote Post
Time is now: 2nd December 2008 - 12:37 AM
