Tags
> Mouse Enter and Leave not fired after minimizing
Yair
post Sep 11 2005, 09:28 AM
Post #1
Extwemely Active
Premium Member
Using LabVIEW Since:2003
LV:7.0 ,7.1 ,.
Israel Nothing Selected Nothing Selected
LabVIEW 7.0, Win XP pro.
When minimizing a LabVIEW window using the FP.State property and then restoring, the Mouse Enter and Mouse Leave events stop firing until you enter another LabVIEW window and then return to normal. This doesn't happen if you use the window's minimize button.
An example is attached.
Attached File(s)
More than meets the eye...
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
m3nth
post Sep 11 2005, 09:36 AM
Post #2
Member
Using LabVIEW Since:2006
LV:8.5 ,. ,.
United States Nothing Selected Nothing Selected
I get the same behavior for LabVIEW 7.1.1, looks like a bug to me. A workaround would probably be to use the window manipulation VI's to minimize programmatically, although I didn't try it myself.
Tags
+Quote Post
Yair
post Sep 11 2005, 11:47 AM
Post #3
Extwemely Active
Premium Member
LV:7.0 ,7.1 ,.
QUOTE (m3nth @ Sep 11 2005, 12:36 PM)
No, just tried it. The winutil VI posts a minimize message to the window, which, I assume, is the same thing the property node does. It seems there is some difference between the minimize button which is part of the window and an external minimize message, although I have no idea if that difference is at the windows level or the LabVIEW level.
Tags
+Quote Post
Time is now: 6th October 2008 - 11:19 PM
