Check out our User Interface Code Repository Files or visit the LabVIEW Wiki User Interface Portal
Tags |
Feb 20 2004, 09:53 PM
Post
#1
One hit wonder! Member Posts: 1 Joined: 20-February 04 Member No.: 278 LV:7.0 |
I am new to Labview and I am wondering if there is a way to do what I want. We have two screens for our application. One has all the controls and the other is an interface to load programs into the PMAC. I wanted to combine these 2 screens into a tab control so I created a tab control and put all the controls from the control screen on it and that worked no problem. But the vi that has all the code to load programs is in its own vi. What I basically wanted to do was insert the "load programs" vi into the second tab of the tab control but can find no way to do this successfully. It seems if I try and copy/paste controls then nothing is wired, and if I copy/paste the block diagram, all the controls on the front panel are not there. Obviously I am either doing something wrong or it can't be done. Can anyone point me in the right direction? Much thanks, Paul Labview 7.0, Windows XP This post has been edited by a_riot: Feb 20 2004, 09:55 PM
| Ad |
Post
Feb 21 2004, 01:04 AM
Post
#2
![]() Extremely Active JKI ![]() Posts: 612 Joined: 19-June 03 From: Bay Area, CA (USA) Member No.: 121 Using LabVIEW Since:1998 LV:8.5.1 ,8.6 ,8.2.1
My Blog
For what you are describing a subpanel will do just fine.
Put a subpanel control (from the container palette) inside you 2nd tab and then you can run your SubVI and display its front panel in the subpanel. For more info on subpanels and how they work, search LV7.0 examples PJM --------------------
| Time is now: 1st December 2008 - 09:24 PM |
