> Related links
Visit our LabVIEW Wiki Hardware Portal
Tags
> How to make PCI-6534 read a voltage of 200mV
ayumisano
post Aug 21 2005, 10:07 AM
Post #1
More Active
Member
LV:6.1
Hong Kong
Dear all,
Is it possible to make PCI-6534 to read the input which is around 200mV? I read the datasheet which is available on ni.com and it says that PCI-6534 is 5V TTL. Does it mean that there is no way for it to trigger a reading as long as the voltage is smaller than 5V?
Thank you very much for your attention!!
Ayumi
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
m3nth
post Aug 22 2005, 11:39 AM
Post #2
Member
Using LabVIEW Since:2006
LV:8.5 ,. ,.
United States Nothing Selected Nothing Selected
QUOTE (ayumisano @ Aug 21 2005, 05:07 AM)
Dear all,
Ayumi
Well since the TTL specification says that a '0' is anything < 0.5V and a '1' is anything > 2.5V, the most straightforward answer is no, you can't trigger a 5V TTL signal with only 200mV.
There is most likely a workaround however. Does the 200mV incoming signal meet some kind of spec? What about using a standard RS422/485->RS232 converter? Those use a voltage differential to determine a '0' or '1' where everything between -200mV to 200mV is no man's land, but maybe you could rig a workaround.
If you have the abililty to use other hardware it probably won't be a problem to find a workaround, but by itself, I don't think you'll be able to tirgger the PCI-6534 directly.
Tags
+Quote Post
Neville D
post Aug 22 2005, 05:21 PM
Post #3
Member
Using LabVIEW Since:1996
LV:8.5.1 ,8.6 ,.
Canada Nothing Selected Nothing Selected
QUOTE (ayumisano @ Aug 21 2005, 03:07 AM)
Dear all,
Ayumi
You could continuously read the input and discard data that doesn't fall within your criteria (200mV or whatever).
Neville.
Tags
+Quote Post
m3nth
post Aug 22 2005, 07:47 PM
Post #4
Member
LV:8.5 ,. ,.
QUOTE (Neville D @ Aug 22 2005, 12:21 PM)
Neville.
TTL is digital, not analog... you can't check voltages in between unless you're doing an analog acquisition.
Tags
+Quote Post
AnalogKid2Digita...
post Aug 22 2005, 09:49 PM
Post #5
Member
Using LabVIEW Since:2000
LV:8.20 ,. ,.
You could wire up a comparator chip to output TTL logic levels based on a 200mV threshold.
‘It’s the questions that drive us'
Tags
+Quote Post
ayumisano
post Aug 28 2005, 06:48 AM
Post #6
More Active
Member
LV:6.1
Hong Kong
QUOTE (AnalogKid2DigitalMan @ Aug 23 2005, 05:49 AM)
Dear all,
Ayumi
Tags
+Quote Post
Time is now: 2nd December 2008 - 12:05 AM
