Feb 16 2004, 07:52 PM
Post
#1
More Active Member Posts: 26 Joined: 16-February 04 Member No.: 274 LV:7.1
NI acknowledges this is a bug and has corrected the problem but the fix will not show up until the next full release. My applications typically use a custom run-time menu so turning the run time menu off is not a solution. Anyone else having this problem or found a solution? Problem exist on Windows 2000 & XP with LabVIEW 7.0 Tags
| Ad |
Post
Tags
Oct 15 2005, 08:29 PM
Post
#2
More Active Member Posts: 33 Joined: 2-September 05 From: Oakmont, PA Member No.: 2910 Using LabVIEW Since:1995 LV:6.1 ,5.1 ,8.20
NI acknowledges this is a bug and has corrected the problem but the fix will not show up until the next full release. Anyone else having this problem or found a solution? Problem exist on Windows 2000 & XP with LabVIEW 7.0 I realize this is a very old topic, but no one ever addresed it. So maybe you are still angry. I see this same bug in LV6.1 WinXP. But untill I read this topic I didn't even know the Alt shortcut was an option, and I use menus a lot. (note to self: RTFM) I have only used the Ctrl key for shortcuts. I noticed the Alt key has no effect on the CPU if there are no Alt shortcuts in the menu. So that's one option. And I guess in this case ignorence was bliss. Also, now that LV8 is out, I wonder if anyone has noticed if NI remembered to fix this bug? (if not move this topic to LV8 bug list) -WDC Tags
Oct 17 2005, 01:42 PM
Post
#3
I realize this is a very old topic, but no one ever addresed it. So maybe you are still angry. I see this same bug in LV6.1 WinXP. But untill I read this topic I didn't even know the Alt shortcut was an option, and I use menus a lot. (note to self: RTFM) I have only used the Ctrl key for shortcuts. I noticed the Alt key has no effect on the CPU if there are no Alt shortcuts in the menu. So that's one option. And I guess in this case ignorence was bliss. Also, now that LV8 is out, I wonder if anyone has noticed if NI remembered to fix this bug? (if not move this topic to LV8 bug list) -WDC You are right that this is an old topic. However there was more activity on this topic in other postings and I did finally get a warm fuzzy about version 7. I will try to bring to recollection some of the specifics about why this finally went from a mountain to a molehill. I finally went to version 7 after determining that LabVIEW did yield the processor back for other request. Or at least I was unable to find any occurrence where I lost data as a result of this quirk. Also if a menu item would drop down when the Alt Key was pressed the processor did not go 100%. By not having a hot key assigned to the top menu item (using the _Menu method to make the Alt-M hot) the menu will drop down to display the sub menu items, if this happens the processor does not go to 100%. In version 7.1 I believe this was corrected. I have yet to load 8, but hopefully this will not reappear. I did not experience any problems with version 6.1 but was told some had this problem with version 6.0 Regards, Randall Tags
Similar Topics
| Topic Title | Replies | Topic Starter | Views | Last Action | |||
17 | JPrevost | 3054 | 13th January 2006 - 11:27 PM Last post by: jbrohan |
10 | Paul | 1911 | 13th August 2004 - 01:57 PM Last post by: Jack Kelledes |
1 | Irene_he | 1791 | 24th September 2005 - 02:47 AM Last post by: Irene_he |
7 | mallika | 2113 | 19th March 2006 - 03:30 PM Last post by: Louis Manfredi |
| Time is now: 6th October 2008 - 02:19 PM |
