> Related links
Tags
> For Next Loop
rimer
post Feb 13 2004, 03:45 PM
Post #1
I want a LabVIEW icon under my name!
Member
LV:6.1
I am totally new to Labview programming and I guess I haven't yet fully learned the ropes. unsure.gif
I have two numeric controls and a numeric indicator on the front panel. The two controls represent starting and ending values. I want to display the numbers from start value, start value plus one to end value sequentially on the display but only when I receive a (boolean?) response from the rest of the block diagram.
Thanks!
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Norm Kirchner
post Feb 13 2004, 05:43 PM
Post #2
Premium Member
Using LabVIEW Since:2000
LV:8.6 ,8.2.1 ,7.1.1
United States us_texas us_ohio My Gallery
Something like this?
See attached picture
This post has been edited by njkirchner: Feb 13 2004, 05:43 PM
Attached thumbnail(s)
Norman J. Kirchner Jr.
Automation Software Engineer
~,~ The Captain Was Here
Premium Blend
Tags
+Quote Post
rimer
post Feb 13 2004, 06:19 PM
Post #3
Member
LV:6.1
Hello njkirchner ,
I am thankful for your quick response. I built and tried the vi and found that it counts up to n-1 rather than n. If my second numeric control is set to 10 the max count will be 9. Any ideas on fixing it? Also is there a way of resetting the numeric indicator to 0 at start up?
Tags
+Quote Post
Michael_Aivaliot...
post Feb 15 2004, 07:43 PM
Post #4
Group Icon
Admin
Using LabVIEW Since:1994
LV:8.5 ,8.2.1 ,7.1.1
I would recommend that you read-up on FOR loops... book.gif The loop will iterate for the number wired inthe the N terminal. All you need to do is +1 to that number and it will iterate one more time.
If you need to reset any control, you can use a local variable. You can use them to write 0's to the controls. Put the reset code outside, before you enter the loop.
Tags
+Quote Post
rimer
post Feb 15 2004, 07:47 PM
Post #5
Member
LV:6.1
oops.gif Thanks Michael,I will follow your advice!
Tags
+Quote Post
Time is now: 1st December 2008 - 11:08 PM
