Tags |
Aug 4 2005, 08:32 AM
Post
#1
More Active Member Posts: 43 Joined: 2-October 03 From: Eindhoven Netherlands Member No.: 175 Using LabVIEW Since:1993 LV:8.5 ,8.2.1 ,7.1.1
When updating the subpanel you need to force an update otherwise the redraw is missed.
I noticed this when loading front panels that were shifted a few mm and it looked ok but when you pressed a button, nothing happened. It appeared to be that the actual button was a few mm shifted from the drawing. by forcing a redraw (minimising and opening again, or by hiding the front panel with another window) the error became clear. In the subvi a redraw is forced by modifying the background color of the transparent background. You don't see it but it helps.
subpanel_update_bug.zip ( 49.52K )
Number of downloads: 244-------------------- Albert Geven
Tel +31 (0)40 27 47234 Philips Research prof Holstlaan 4 (WY 06) 5656AA Eindhoven
| Ad |
Post
| Time is now: 1st December 2008 - 11:47 PM |
