Tags |
Feb 2 2004, 08:22 AM
Post
#1
Active Member Posts: 10 Joined: 16-December 03 Member No.: 220 |
I'm using the "read from file" VI and sometimes it produces a one button
error dialog "not enough memory to finish this operation". Is there a possibility to disable this error dialog?
| Ad |
Post
Feb 2 2004, 02:43 PM
Post
#2
![]() Extremely Active Premium Member ![]() Posts: 595 Joined: 8-December 03 From: Dallas, Texas Member No.: 208 Using LabVIEW Since:2000 LV:8.6 ,8.2.1 ,7.1.1
My Gallery
What is the specific error code that it is returning?
What version of LabVIEW are you using? But just to get you going, if you dig in to the read from file, you'll see that there is a general error handler VI. There are 2 inputs to the error handler that you'll be interested in. The Exception Code and Exception Action. Modify this VI to ignore your error and save it as something different. :!: MAKE SURE TO SAVE IT AS A DIFFERENT VI and DO NOT UPDATE CALLERS. -Hope this gets you running -------------------- Norman J. Kirchner Jr.
Automation Software Engineer ~,~ The Captain Was Here Premium Blend ![]()
| Time is now: 1st December 2008 - 10:42 PM |
