Tags
> Enum Constant not so constant, Something causes the value to switch
jcabrer
post May 26 2005, 06:04 PM
Post #1
5 more posts to go!
Member
Using LabVIEW Since:1996
LV:8.5 ,7.1 ,7.0
United States Puerto Rico spn_Catalonia
I'm using an unamed queue to store states in the order I want them to execute, so I have an INIT state where I pump 10 states into the queue. The application recieves the initial state from an Enum constant wired from outside the main while loop.
The problem is that when the application runs, the first Enum inside the init state, which has a numerical value of (4), changes to (0) INIT all by itself. There are no property nodes or anything else that I can think of that might be affecting this.
If I remove the constant, and replace it with a control, and then change the control to a constant, the problem disappears!
This post has been edited by jcabrer: May 26 2005, 06:09 PM
Attached File(s)
Attached File  tRXpUMP_with_enum_bug.VI ( 131.14K ) Number of downloads: 247
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
i2dx
post May 27 2005, 05:56 AM
Post #2
(n0ob)²
Member
Using LabVIEW Since:2001
LV:8.20 ,7.1.1 ,.
ger_bavaria Germany ger_rhineland
i agree there is a bug ...
very strange !
take a look at the attatched VI, there is a solution how to avoid this ....
best regards,
cb
Attached File(s)
Attached File  tRXpUMP_with_enum_bug_simple.VI ( 80.94K ) Number of downloads: 249
don't take me to serious
my Website my ADO-Toolkit for LabVIEW™
Tags
+Quote Post
Time is now: 1st December 2008 - 10:40 PM
