Check out our OOP Code Repository Files or visit the LabVIEW Wiki OOP Portal.
Tags |
Jan 16 2004, 05:33 AM
Post
#1
![]() Very Active Member Posts: 116 Joined: 9-June 03 From: Perth, Western Australia Member No.: 111 Using LabVIEW Since:2006 LV:6.0.2 ,. ,.
I have played a little with the new PDA module. It doesn't allow GOOP objects (I have only tested this on Palm, not PocketPC). Is this because occurrences don't work on the Palm? Anyone have any clues?
cheers, Alex. -------------------- "Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the universe trying to build bigger and better idiots. So far, the universe is winning." Robert Cringley.
| Ad |
Post
Feb 16 2004, 05:42 PM
Post
#2
I've come back for more. NI ![]() Posts: 2 Joined: 16-February 04 From: Austin, TX Member No.: 273 LV:6.0
Occurences work with the PDA module. I've never used the GOOP module. Perhaps it uses variants? Those are not supported in the PDA module.
Regards, Andrew
Feb 18 2004, 03:17 AM
Post
#3
Maybe it does at the lowest level. It would be nice to program using GOOP, but it does come with an overhead, and maybe that would be prohibitive on the PDA.
Mar 25 2004, 10:20 PM
Post
#4
Changing the world, one VI at a time. JKI ![]() Posts: 1696 Joined: 22-October 02 From: San Francisco, CA Member No.: 17 Using LabVIEW Since:1995 LV:8.2.1 ,8.5 ,7.1.1
My Blog
My Gallery
Alex,
-Jim --------------------
Sep 21 2005, 09:44 PM
Post
#5
![]() More Active Member Posts: 37 Joined: 3-December 04 From: Amsterdam, The Netherlands Member No.: 1175 Using LabVIEW Since:2003 LV:8.5.1 ,. ,.
I know I haven't got the fastest response time, but what I do is in real time
The PDA module only has some kind of make believe vi server: it only supports a few properties. That seems to be the most obvious problem to me. It gets even more annoying, because it also behaves inconsistent with clustered data that is any more than simple. --------------------
| Time is now: 1st December 2008 - 09:30 PM |
