> Related links
Check out our User Interface Code Repository Files or visit the LabVIEW Wiki User Interface Portal
Tags
> How to deal with different DPI settings?
Mike C
post Apr 15 2005, 05:01 PM
Post #1
More Active
Member
Using LabVIEW Since:1998
LV:8.5 ,. ,.
United States Cyprus Nothing Selected
I have an interesting situation. I am developing programs for a small research group where my users have different DPI settings on their machines (some have normal size and some have large size). My system is set to normal size. The front panel of any application I develop is messed up on the machines where the large size is set. Is there a way to make the front panel of my applications look the same in either case (other than forcing everybody to the same dpi settings)?
Thanks,
MikeC
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
JohnRH
post Apr 15 2005, 08:41 PM
Post #2
Member
LV:8.6 ,. ,.
United States us_virginia Canada
About the only thing I can think of is to replace your text wth graphics. Not that bad for simple stuff, but a pain in the but for anything containing a lot of controls and indicators.
QUOTE (Mike C @ Apr 15 2005, 12:01 PM)
Thanks,
  MikeC
John Howard
Test Engineer, NIITEK
"Before the First Step"
Tags
+Quote Post
RandyR
post Apr 15 2005, 09:45 PM
Post #3
Active
Member
LV:8.0
Nothing Selected Nothing Selected Nothing Selected
Thanks,
  MikeC
I assume you're talking about large fonts... You can, in the .ini file for your app, set a specific font that will override the Windows large font setting. The way I've discovered best to handle this is to set the 'application', 'dialog' and 'system' font setting to custom and select my desired font in the LabVIEW development environment for developing the app. Then, just make sure you copy the font setting out of the LabVIEW.ini file into your app's ini file. The font settings look like this...
appFont="Tahoma" 13
dialogFont="Tahoma" 13
systemFont="Tahoma" 13
A couple of hints: I don't set any font in my app (on the controls or indicators, etc.) to anything other than application, dialog or system. In other words, never set a specific font on a front panel, always let the desired font propagate to the controls/indicators via the default methods. Along the same lines, when you're setting, say, the application font default in the options screen, never check either the 'panel default' or 'diagram default' in the font browser. This will make stuff have specific font settings (other than application, dialog or system) and can drive you mad tracking it all down to get everything to match up. Obviously, there are exceptions to this when you may need an indicator or two to stand out or something.
Also, you need to be sure that the font you choose is going to be present on the other machines the app will install on. As best as I can tell, 'Tahoma' is the default 2000/XP font, so that's the one I use.
Randy
Tags
+Quote Post
Mike C
post Apr 18 2005, 01:11 PM
Post #4
More Active
Member
LV:8.5 ,. ,.
QUOTE (RandyR @ Apr 15 2005, 04:45 PM)
appFont="Tahoma" 13
Randy
Thanks for all the help RandyR
Tags
+Quote Post
Time is now: 2nd December 2008 - 12:04 AM
