> Related links
Check out our Database and File IO Code Repository Files or visit the LabVIEW Wiki Database and File IO articles.
Tags
> SQL toolkit variant problems, Help!
atk_nut
post Apr 7 2005, 10:54 PM
Post #1
Active
Member
LV:7.0
Canada
OK, here's the issue. I'm trying to duplicate a record with the SQL toolkit. In the insert record vi, it takes a cluster of data, converts it to variant, parses the datatypes and inserts the record.
What I want to do, is develop a vi that programmatically inserts a record based on the column info and an array of strings. (In stead of building a cluster to pass to the vi.) The problem is, how do you "build" a cluster variant from an array of strings.
I have attached a vi that illustrates the problem. The goal: Make variant2 look like variant1!
Any help would be appreciated.
Attached File(s)
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
atk_nut
post Apr 19 2005, 10:11 PM
Post #2
Active
Member
LV:7.0
Canada
Ok.
It turns out it was simpler than I thought (If you have OpenG installed.)
See attached.
Attached File(s)
Tags
+Quote Post
Time is now: 2nd December 2008 - 12:26 AM
