> Related links
Check out our User Interface Code Repository Files or visit the LabVIEW Wiki User Interface Portal
Tags
> Controlling Grid Spacing in Chart?
jorourke
post Mar 3 2005, 07:30 PM
Post #1
2 more posts to go!
Member
LV:7.1
Hi
In a waveform chart how is grid spacing defined? I have an application where the user would like to view the data without any grid lines 90% of the time. For ease of quantifying, he would like to be able to turn the grid lines on and off and be able define the grid spacing from the front panel. Turning the grid on and off is easy using the chart properties, YScale.MnrGrdColor and YScale.MajGrdColor. How would I go about changing the spacing of the grids?
Thanks
John
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
dswaine
post Mar 3 2005, 11:10 PM
Post #2
Active
Member
Using LabVIEW Since:1992
LV:6.1 ,2.2 ,.
Canada ca_ontario Nothing Selected
Things may have moved a bit in v7, but try YScale.Range. ... to access Increment, Minor Increment and Start. "Start" is the value of the first major gridline which (I think) defaults to a multiple of Increment.
Attached image(s)
Tags
+Quote Post
Time is now: 2nd December 2008 - 12:57 AM
