Visit our LabVIEW Wiki Real Time article
Tags |
Oct 6 2008, 04:42 PM
Post
#1
Active Member Posts: 10 Joined: 4-October 08 From: GREECE-THESSALONIKI Member No.: 12900 Using LabVIEW Since:2008 LV:8.5 ,. ,.
hello everybody...
i'm a new user of Labview,and i have to say that i found it very interesting. i want to ask you some questions before i start a project,if anyone can help me. i will communicate with a microcontroller (Pic) the kind of connection will be via ethernet port. i did not found any example to show me the way to do this. is it possible,this kind of communication? thank you ..
| Ad |
Post
Oct 6 2008, 05:53 PM
Post
#2
Active Member Posts: 13 Joined: 6-October 08 Member No.: 13036 Using LabVIEW Since:2007 LV:8.5 ,. ,.
Hello Pantelis and all of you guys
I have the same question with Pantelis. I want to make a microcontroller of PIC family to communicate with labview through ethernet. I think that i have to do something with IP and Mac address but I don't know exactly what to do. Does anyone have any idea who to do this? (Sorry about my English....) Thank you for your time..... This post has been edited by d_nikolaos: Oct 6 2008, 05:55 PM |
Oct 6 2008, 06:33 PM
Post
#3
![]() Extwemely Active Premium Member ![]() Posts: 1632 Joined: 23-January 05 From: Here Member No.: 1431 Using LabVIEW Since:2003 LV:8.6 ,7.0 ,.
Many people have interacted with microcontrollers and if you search both here and in NI's forums you should find many threads.
Additionally you can find shipping examples in LabVIEW's example finder (in the help menu). You probably want TCP related examples. You should start by going through some tutorials first, though. -------------------- More than meets the eye...
Oct 6 2008, 06:46 PM
Post
#4
thank's a lot ..
i will have a look..
Oct 6 2008, 10:04 PM
Post
#5
![]() Very Active Member Posts: 80 Joined: 12-June 08 From: Sydney Member No.: 11757 Using LabVIEW Since:2006 LV:8.5.1 ,8.2.1 ,7.1
thank's a lot .. i will have a look.. I agree, i suggest you to spend about a week with labview tutorials and practice programming. Then I think you might interested looking at this: http://zone.ni.com/devzone/cda/tut/p/id/6207 good luck, -------------------- Minh Pham <><><>Stop Writing...Start Wiring<><><>
Oct 7 2008, 03:31 AM
Post
#6
1 more post to go! Member Posts: 9 Joined: 5-September 08 Member No.: 12461 Using LabVIEW Since:2002 LV:6.1 ,7.1 ,8.5
v_pan, I have done something similar recentl, with a PIC as well. The hard thing to program is definitely on the PIC side, allocating the correct ressources and Socket type for your connection. LabVIEW is really easy to use once you've been through the tutorials.
About what Minh said in the last post, unfortunately PIC are not ARM microcontrollers and I doubt that NI has any compiler for those yet. You will still have to write your code in good old C! =) Best of luck! Olivier
| Time is now: 2nd December 2008 - 12:15 AM |
