Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Oct 1 2008, 10:45 PM
Post
#1
Very Active Member Posts: 163 Joined: 14-June 05 From: Seattle, WA Member No.: 2411 Using LabVIEW Since:1993 LV:8.5.1 ,8.20 ,7.1.1
Does anyone know if there is an ini setting somewhere that will allow me to change the recent file list in the getting started window?
Under the 'Open' section, it lists recent projects and files. This list matches the file..recent projects/file menu. The problem is, it only lists the two most recent projects. Since the majority of my day-to-day work revolves around several projects, I would like to change this so it lists more projects and less files. Two is just not enough and I end up using the drop down menu instead most of the time. I know this is a minor inconvienence, but it just bugs me after awhile. There should be some why to change this... thanks for the help, -John -------------------- ---------
You mean you still use a keyboard to write your code? How quaint...
| Ad |
Post
Oct 1 2008, 11:06 PM
Post
#2
![]() Very Active Member Posts: 80 Joined: 12-June 08 From: Sydney Member No.: 11757 Using LabVIEW Since:2006 LV:8.5.1 ,8.2.1 ,7.1
Does anyone know if there is an ini setting somewhere that will allow me to change the recent file list in the getting started window? Under the 'Open' section, it lists recent projects and files. This list matches the file..recent projects/file menu. The problem is, it only lists the two most recent projects. Since the majority of my day-to-day work revolves around several projects, I would like to change this so it lists more projects and less files. Two is just not enough and I end up using the drop down menu instead most of the time. I know this is a minor inconvienence, but it just bugs me after awhile. There should be some why to change this... thanks for the help, -John mmm, this sounds pretty cool, I suggest you to have a look to this: http://eyesonvis.blogspot.com/2007/10/cust...ted-window.html I will try to customize my LabVIEW Getting Started Windows as well, cool let me know the result. Good luck -------------------- Minh Pham <><><>Stop Writing...Start Wiring<><><>
Oct 2 2008, 12:46 AM
Post
#3
![]() Extremely Active Premium Member ![]() Posts: 274 Joined: 18-January 08 From: Montréal, Canada Member No.: 10515 Using LabVIEW Since:2000 LV:8.6 ,8.5 ,.
Does anyone know if there is an ini setting somewhere that will allow me to change the recent file list in the getting started window? Under the 'Open' section, it lists recent projects and files. This list matches the file..recent projects/file menu. The problem is, it only lists the two most recent projects. Since the majority of my day-to-day work revolves around several projects, I would like to change this so it lists more projects and less files. Two is just not enough and I end up using the drop down menu instead most of the time. I know this is a minor inconvienence, but it just bugs me after awhile. There should be some why to change this... thanks for the help, -John Hi John, Have a look at this topic where I asked exactly the same question. AQ was generous enough to change the VI and allow for an input for # of lvproj wanted. Then, PJM suggested we could write our own and replace it. There is a method for Recently Opened VIs and LVproj (which just accesses the INI file).
Oct 2 2008, 06:03 PM
Post
#4
Have a look at this topic where I asked exactly the same question. Thanks! That did the trick! Maybe they will incorporate this into the next LabVIEW release as an ini setting. -John -------------------- ---------
| Time is now: 2nd December 2008 - 12:10 AM |
