Tags |
Sep 16 2008, 12:50 AM
Post
#1
Very Active Member Posts: 163 Joined: 14-June 05 From: Seattle, WA Member No.: 2411 Using LabVIEW Since:1993 LV:8.5.1 ,8.20 ,7.1.1
Here is an example of how to center your dialog boxes on the front panel of your application. This uses a set of utility VIs I created that will allow you to specify the VI to center on. If you do not specify a VI, then it will search the call chain for the nearest caller who has an open front panel. If there are no VIs in the call chain open, then it will center it on the screen.
I use this a lot in my applications. I hope you find it useful as well. -John
EXAMPLE_centering_dialog_box.zip ( 76.11K )
Number of downloads: 47-------------------- ---------
You mean you still use a keyboard to write your code? How quaint...
| Ad |
Post
| Time is now: 1st December 2008 - 09:13 PM |
