Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Sep 9 2008, 07:14 PM
Post
#1
Very Active Member Posts: 115 Joined: 26-January 07 From: Seattle, WA Member No.: 7603 Using LabVIEW Since:2006 LV:8.20 ,. ,.
Is there some special technique required to insert a class cube on a custom palette? I've tried several times but it doesn't seem to be working.
| Ad |
Post
Sep 9 2008, 09:13 PM
Post
#2
![]() Extremely Active Premium Member ![]() Posts: 274 Joined: 18-January 08 From: Montréal, Canada Member No.: 10515 Using LabVIEW Since:2000 LV:8.6 ,8.5 ,.
Is there some special technique required to insert a class cube on a custom palette? I've tried several times but it doesn't seem to be working. The Class Cube is a built-in function and I don't think you can access it. In the palette editor, when selecting "Display path to palette file...", you get a message saying it's built-in. However, if you create a control and put the class cube in (type def or not), you can insert this wrapper control in any palette or save it to user.lib.
Sep 9 2008, 10:44 PM
Post
#3
![]() LV R&D Envoy NI ![]() Posts: 1226 Joined: 15-August 06 From: Austin, TX Member No.: 5877 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Gallery
The Class Cube is a built-in function and I don't think you can access it. In the palette editor, when selecting "Display path to palette file...", you get a message saying it's built-in. That particular cube is for "LabVIEW Object", which is indeed built-in. But for classes in general, you should be able to add to the palette just by selecting the .lvclass file. However, this is not working in LabVIEW 8.2, 8.5 or 8.6 (it did work in LV8.2 beta, but broke for some reason in the actual release). No one noticed that until very recently. But the workaround, as has already been mentioned, is easy enough. QUOTE However, if you create a control and put the class cube in (type def or not), you can insert this wrapper control in any palette or save it to user.lib. If you want to insert the block diagram constant into the Functions palette, you can create a VI that has nothing except the constant on its diagram and then add it to the palette as a Merge VI. -------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D
| Time is now: 1st December 2008 - 11:52 PM |
