Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Sep 9 2008, 03:09 PM
Post
#1
I've come back for more. Member Posts: 2 Joined: 21-July 08 Member No.: 12066 Using LabVIEW Since:2008 LV:6.0 ,8.20 ,8.5.1
I got some code from the Indian testo webpage, when I try to run the Vis, all the properties nodes and invoke nodes seems to be broken, becose the error list show me the items with the warnings.
I`ve been trying to built them againg but I can`t.
Attached File(s)
| Ad |
Post
Sep 9 2008, 03:49 PM
Post
#2
![]() Very Active Premium Member ![]() Posts: 90 Joined: 12-November 04 From: Gatineau, Quebec, Canada Member No.: 1022 Using LabVIEW Since:2001 LV:8.6 ,8.5.1 ,.
I got some code from the Indian testo webpage, when I try to run the Vis, all the properties nodes and invoke nodes seems to be broken, becose the error list show me the items with the warnings. I`ve been trying to built them againg but I can`t. I am seeing the same thing. The reason seems to be a missing ActiveX class or control. Was there a dll file that came with the LabVIEW code? If so, try to register it with windows, restart LabVIEW, and see if it works.
Sep 25 2008, 04:27 PM
Post
#3
I found the missing DLL, but also It seems that If i want to use the device i have to call excel and from it use the visual basic editor to load a special the Dll, seee attachment.
Attached File(s)
FAQ___Toolbox___tccdk_einbinden.doc ( 172.5K )
testoDLL.zip ( 222.57K )
Sep 26 2008, 03:52 PM
Post
#4
I found the missing DLL, but also It seems that If i want to use the device i have to call excel and from it use the visual basic editor to load a special the Dll, seee attachment. Sorry, but I am unable to open the zip file. As for Excel, from the document it looks like this is they way to use it in Excel. You would have to do the similar thing in LabView to use it. Namely right click the ActiveX Refnum on the front panel and choose Select ActiveX class -> Browse... In the ActiveX Class Browser click on Browse... and navigate to the dll. ![]() Hope that helps. Heiko
| Time is now: 1st December 2008 - 10:46 PM |
