Visit our LabVIEW Wiki Code Distribution Portal
Tags |
Sep 8 2008, 03:39 PM
Post
#1
![]() Extremely Active Premium Member ![]() Posts: 595 Joined: 8-December 03 From: Dallas, Texas Member No.: 208 Using LabVIEW Since:2000 LV:8.6 ,8.2.1 ,7.1.1
My Gallery
Ok, something is fishy here.
I've got a program that is not complex by any stretch of the imagination. I've got some LVOOP stuff in there but very simple structure 1 class owns 2 other classes, no inheritance. and the LVx package that does have inheritance, but has been built in 8.2 before w/out issue And as I try to build it into an EXE, going on minute #5 now, I am still waiting for the build to initialize... WTF!!!! Never have I seen it need to sit so long for an init of a build, but it will finish eventually... like the moment I walk away because I'm tired of trying to see how long it takes and give up. So the question is, has anyone had a simple program cause the EXE builder to take FOREVER on the init of the build? Going to start an NI SR as well but wanted to see what others have seen. -------------------- Norman J. Kirchner Jr.
Automation Software Engineer ~,~ The Captain Was Here Premium Blend ![]()
| Ad |
Post
Oct 16 2008, 11:40 PM
Post
#2
Active Member Posts: 10 Joined: 29-June 07 From: Burbank, CA Member No.: 8830 Using LabVIEW Since:1992 LV:8.6 ,8.5.1 ,8.2.1
Ok, something is fishy here. I've got a program that is not complex by any stretch of the imagination. I've got some LVOOP stuff in there but very simple structure 1 class owns 2 other classes, no inheritance. and the LVx package that does have inheritance, but has been built in 8.2 before w/out issue And as I try to build it into an EXE, going on minute #5 now, I am still waiting for the build to initialize... WTF!!!! Never have I seen it need to sit so long for an init of a build, but it will finish eventually... like the moment I walk away because I'm tired of trying to see how long it takes and give up. So the question is, has anyone had a simple program cause the EXE builder to take FOREVER on the init of the build? Going to start an NI SR as well but wanted to see what others have seen. Norm, I started a Service Request for the same issue. According to NI this is a known bug with Labview 8.6 Build times have more than doubled between Labview 8.5.1 and Labview 8.6 bluesky
Oct 17 2008, 12:04 AM
Post
#3
Very Active NI ![]() Posts: 95 Joined: 12-December 05 From: Austin, TX Member No.: 3674 LV:8.0
Norm, I started a Service Request for the same issue. According to NI this is a known bug with Labview 8.6 Build times have more than doubled between Labview 8.5.1 and Labview 8.6 bluesky Do you have the service request number? I am not aware of build times slowing down by 2x between versions. In your particular situation, do you have build times for both 8.5 and 8.6?
Oct 17 2008, 04:56 PM
Post
#4
Do you have the service request number? I am not aware of build times slowing down by 2x between versions. In your particular situation, do you have build times for both 8.5 and 8.6? My service request number is 7212358. NI tech support confirmed that this was a know issue. bluesky
Oct 17 2008, 05:26 PM
Post
#5
My service request number is 7212358. NI tech support confirmed that this was a know issue. bluesky Thank you for the information. There appears to be a slight slowdown in general, but not an across the board 2x difference. Some applications have been reported to be slower by this factor, but it is on a case by case basis. Thank you for reporting this.
| Time is now: 2nd December 2008 - 12:52 AM |
