Tags |
Sep 5 2008, 09:22 PM
Post
#1
I've come back for more. Member Posts: 2 Joined: 18-June 08 Member No.: 11794 Using LabVIEW Since:2008 LV:8.5.1 ,. ,.
I am relatively new to LabVIEW and wasn't able to find a way of doing this on my own: At the end of an App that I have written I want the user to be able to open the folder to which all of his output files were saved. How can I do this? Thanks in advance.
| Ad |
Post
Sep 5 2008, 09:54 PM
Post
#2
![]() Extremely Active Premium Member ![]() Posts: 595 Joined: 8-December 03 From: Dallas, Texas Member No.: 208 Using LabVIEW Since:2000 LV:8.6 ,8.2.1 ,7.1.1
My Gallery
I can't say specifically how to do it, but I know there is no native way in LabVIEW to accomplish this.
What I would expect the answer to be, is that you will call the SystemExec command (executes command line operations) to some component of .... wait... this is easier than I'm making it out to be. ![]() yup... that works. Just call that at the end of your program w/ the appropriate path worked into the end of the string. -------------------- Norman J. Kirchner Jr.
Automation Software Engineer ~,~ The Captain Was Here Premium Blend ![]()
Sep 5 2008, 10:05 PM
Post
#3
![]() Very Active Premium Member ![]() Posts: 217 Joined: 31-January 03 From: Wilson NC USA Member No.: 48 Using LabVIEW Since:2001 LV:8.5 ,. ,.
You can execute a windows commands using the SystemExec vi. If you give it the string:
run c:\ You will get and explorer window of C:\ There are variuos obscure commands and syntax that will cause the explorer window to look certain ways, such as with the folder tree present, and so on. I don't have a reference for you on that, but knowing about it should help. So assemble a string that does what you want and wire it to the SysExec vi and you are good to go. Mike -------------------- Michael E. Ross
Senior Design Engineer Standard Motor Products, Inc. 2717 Commerce Road Wilson, NC 27893 mross@smpcorp.com 252.234.5821
Sep 6 2008, 05:25 AM
Post
#4
![]() I'm a LAVA, not a fighter. V I Engineering, Inc. ![]() Posts: 3750 Joined: 13-October 03 From: Michigan, USA Member No.: 181 Using LabVIEW Since:1993 LV:8.5 ,. ,.
My Blog
At the end of an App that I have written I want the user to be able to open the folder to which all of his output files were saved. Feed the path into "Open URL in Default Browser.vi"
Sep 8 2008, 03:22 PM
Post
#5
Thanks a lot.
| Time is now: 1st December 2008 - 10:56 PM |
