> Related links
Visit our LabVIEW Wiki Code Distribution Portal
Tags
> INI file for my application
pikro
post Sep 5 2008, 10:28 AM
Post #1
1 more post to go!
Member
Using LabVIEW Since:2008
LV:8.0 ,. ,.
Czech Republic Nothing Selected Nothing Selected
Hi, I have confiuration file defaults.ini for my application. When I compile it and then run it, i see always the message : ["C:\MyApplication\MyApplication.exe\defaults.ini" not found]. I have tried to change in MyApplication Property - Advanced - Configuration file form LabView.ini to my file defaults.ini. But it still doesn't work sad.gif Does someone have any idea where is the problem? (LabView 8.6)
This post has been edited by pikro: Sep 5 2008, 10:48 AM
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
shoneill
post Sep 5 2008, 10:42 AM
Post #2
Member
Using LabVIEW Since:2006
LV:8.2.1 ,8.20 ,6.1
Ireland Switzerland Nothing Selected
QUOTE (pikro @ Sep 5 2008, 12:28 PM) *
Hi, I have confiuration file defaults.ini file for my application. When I compile it and then run it. Every time i see message : "C:\MyApplication\MyApplication.exe\defaults.ini" not found. I have tried in MyApplication Property - Advanced - Change configuration file form LabView.ini to my file defaults.ini. But it still doesnt work sad.gif Have some one idea where is the problem? (LabView 8.6)
When you get the path of a VI from within an EXE, the name of the EXE is treated as a folder. The EXE is basically just a glorified LLB.
You need to strip one extra level from the "this VI's Path" to get the containing folder after making an EXE. Pain in the rear I know, but once you know about it, you'll know in future.
Shane.
Tags
+Quote Post
LV_FPGA_SE
post Sep 5 2008, 03:33 PM
Post #3
NI
Using LabVIEW Since:1993
LV:8.5.1 ,8.2.1 ,8.6
us_texas Canada Germany My Gallery
QUOTE (shoneill @ Sep 5 2008, 05:42 AM) *
Shane.
Here's an example of how to get the path of a calling VI and automatically strip the EXE if necessary. VI and project are attached.
Attached File(s)
Christian L
NI Systems Engineering - Real-Time and Embedded Control Technologies
"I like my G code neat."
Tags
+Quote Post
Yair
post Sep 6 2008, 06:17 PM
Post #4
Extwemely Active
Premium Member
Using LabVIEW Since:2003
LV:8.6 ,7.0 ,.
Israel Nothing Selected Nothing Selected
Et tu, Christian?
While that method is reasonably likely to work (at least in Windows), it fails to account for many corner cases (e.g. non-Windows OS, a VI in an LLB, a VI whose extension is .exe, etc.). A more robust way would be to do something like this:
Incidentally, this example has its own problems (the top level VI might not always be what you think), but the stripping part is sound.
More than meets the eye...
Tags
+Quote Post
pikro
post Sep 9 2008, 07:43 AM
Post #5
1 more post to go!
Member
LV:8.0 ,. ,.
QUOTE (Yair @ Sep 6 2008, 08:17 PM) *
Et tu, Christian?
Thank you for help. This solution doesn´t work, but on your link i found similar way with case structure. And that work.
Tags
+Quote Post
Yair
post Sep 9 2008, 04:53 PM
Post #6
Extwemely Active
Premium Member
LV:8.6 ,7.0 ,.
QUOTE (pikro @ Sep 9 2008, 10:43 AM) *
That code works just fine. As I mentioned, the part on the left (getting the name of the top level VI) might not behave as you expect under all circumstances, but the loop was the important part of the code.
Tags
+Quote Post
Time is now: 1st December 2008 - 08:21 PM
