Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Sep 2 2008, 01:03 PM
Post
#1
Very Active Member Posts: 227 Joined: 19-August 05 From: Minneapolis, MN Member No.: 2786 Using LabVIEW Since:1995 LV:8.20 ,. ,.
I'm getting the following runtime error when my LabVIEW 8.6 code encounters a TDMS Write VI.
![]() The error makes no sense to me. The odd thing is that I have other TDMS Write VIs in my code that work fine. It's only when it encounters this VI in a particular place (I put a breakpoint right before it and the error pops up when I single step). I've tried replacing the VI, but that didn't help. Does anyone have any clue what this error means? Why the heck is MS Visual C++ involved? George I figured it out. I was feeding the VI a bad file reference. The error still seems all wrong to me though. Plus it shut down LabVIEW which seems totally unnecessary. This post has been edited by george seifert: Sep 2 2008, 01:48 PM
| Ad |
Post
Sep 2 2008, 03:13 PM
Post
#2
![]() LV R&D Envoy NI ![]() Posts: 1226 Joined: 15-August 06 From: Austin, TX Member No.: 5877 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Gallery
You are completely correct that merely wiring a bad file reference should not generate this error. This is the dialog that gets displayed when LabVIEW attempts something illegal or unexplainable, such as a VI jumping to an undefined memory address. It means you found a place where our compiler failed to generate valid code or the VI itself was somehow corrupted on disk. If this is repeatable, please please please post your situation on ni.com so the AEs can work with you to identify the problem and get it fixed in the next version of LV. We ought to be handling bad file reference more gracefully (ie merely returning an error code cluster).
-------------------- "A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D
| Time is now: 1st December 2008 - 06:21 PM |
