Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Sep 2 2008, 06:11 AM
Post
#1
I want a LabVIEW icon under my name! Member Posts: 3 Joined: 30-November 06 From: Bangalore,India Member No.: 7061 Using LabVIEW Since:2002 LV:7.1 ,8.20 ,8.5
I had a requirement to convert a html file to a pdf using a VI.I have tried finding the web for a solution or an idea.But could not find any.Has anyone got an example to convert the same. Regards, Subhasis -------------------- Thanks,
Subhasis Bera
| Ad |
Post
Sep 2 2008, 06:31 AM
Post
#2
![]() CCT It Premium Member ![]() Posts: 1337 Joined: 13-June 05 From: Woerden, Netherlands Member No.: 2399 Using LabVIEW Since:2001 LV:8.5.1 ,6.1 ,8.2.1
My Blog
My Gallery
I had a requirement to convert a html file to a pdf using a VI.I have tried finding the web for a solution or an idea.But could not find any.Has anyone got an example to convert the same. That's not an easy task. Carya has a toolkit to build PDFs Ton --------------------
Sep 2 2008, 03:24 PM
Post
#3
Very Active Member Posts: 99 Joined: 23-February 06 From: Detroit, MI USA Member No.: 4230 Using LabVIEW Since:1994 LV:8.0.1 ,8.5.1 ,7.1
I had a requirement to convert a html file to a pdf using a VI.I have tried finding the web for a solution or an idea.But could not find any.Has anyone got an example to convert the same. Are you converting the code to write a pdf instead of html or converting the existing html to a pdf? I assume the second... It seems the easiest option would be to install a pdf writer (looks like a printer) and then print the html from a web browser, which could be controlled programically using ActiveX or .NET. Tim
Sep 2 2008, 04:54 PM
Post
#4
![]() Active Member Posts: 23 Joined: 28-July 08 From: CT Member No.: 12118 Using LabVIEW Since:2005 LV:8.5.1 ,. ,.
Hi, I had a requirement to convert a html file to a pdf using a VI.I have tried finding the web for a solution or an idea.But could not find any.Has anyone got an example to convert the same. Regards, Subhasis Download a PDF Printer (i.e. CutePDF).. Then write a Labview program to Print the HTML to the PDF Printer.. Done. -Scott
Sep 5 2008, 02:24 PM
Post
#5
Active Member Posts: 20 Joined: 22-October 07 Member No.: 9667 Using LabVIEW Since:2004 LV:8.6 ,8.5.1 ,7.1
An option I useds a while back that worked nicely (although is not free) was to use an ActiveX/.Net component (it comes with both interfaces) called Many2PDF - basically it will, without the need for setting up printers on machines, etc will convert a variety of file formats to a pdf document with no user interaction. We then used the standard LabVIEW HTML reporting tools to create a report (which could be printed if necessary) and every time a report was created, seemlessly save a pdf version (complete with images, tables etc) to disk. If anyone is interested I would be happy to put up my (very basic) VI that that generates uses this tool.
I'm not sure how this would compare to the Carya offereing as I had not come across that one until today! Shaun
| Time is now: 1st December 2008 - 11:50 PM |
