> Related links
Check out the related Code Repository Files or visit the LabVIEW Wiki Internet Portal
Tags
> TCP Communication between VB and LV, TCP with Visual Basic and LabVIEW
Rating 3 V
Giseli Ramos
post Sep 1 2008, 08:13 PM
Post #1
More Active
Member
Using LabVIEW Since:2006
LV:8.5 ,8.2.1 ,8.0
Brazil Nothing Selected Nothing Selected
I have a compiled program (not mine) in VB which acts as a server that receives commands from my LabVIEW application via TCP port. So, these programs run in differents computers in a local network. They works fine when the two computers are Windows.
If my LabVIEW program runs on Linux, it is not able to establish a communication with the VB program. The cause of the problem maybe that the VB program uses Winsock?
I already tested my connection between a Linux and a Win computer using the examples TCP communicator, so the connection is fine.
Thanks!
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Eugen Graf
post Sep 1 2008, 08:25 PM
Post #2
Member
Using LabVIEW Since:2004
LV:8.5 ,8.0.1 ,.
Germany Kazakhstan Russia My Gallery
May be you can try to use Data Socket VIs insted of TCP/IP ?
Tags
+Quote Post
Phillip Brooks
post Sep 1 2008, 11:48 PM
Post #3
Premium Member
Using LabVIEW Since:1999
LV:7.0 ,8.20 ,8.0
us_massachusetts France Thailand My Gallery
QUOTE (Giseli Ramos @ Sep 1 2008, 04:13 PM) *
This may be and endian problem, see here...
Tags
+Quote Post
Ton
post Sep 2 2008, 04:20 AM
Post #4
CCT It
Premium Member
Using LabVIEW Since:2001
LV:8.5.1 ,6.1 ,8.2.1
Netherlands hol_utrecht Nothing Selected My Blog My Gallery
The problem is that you can't establish a connection. Strange, what error code is generated on the LabVIEW side?
Ton
Certified LabVIEW Developer
Shouldn't you be programming a Code Repository solution?
Tags
+Quote Post
Giseli Ramos
post Sep 2 2008, 10:28 AM
Post #5
More Active
Member
LV:8.5 ,8.2.1 ,8.0
QUOTE (Ton @ Sep 2 2008, 01:20 AM) *
Ton
When I try to connect to the VB server using LV, it simply don't connect, I get timeout.
Eugen, I tried something with DataSocket, but I'm not satisfied and really want to use TCP things. Don't have any way really?
Philip, thanks for the tip. I will see here if is this problem and will post here the results.
Tags
+Quote Post
Ton
post Sep 2 2008, 10:53 AM
Post #6
CCT It
Premium Member
QUOTE (Giseli Ramos @ Sep 2 2008, 12:28 PM) *
Do you have the right port and number? It looks like there is no-listening at that port.
Could you post a screenshot?
Ton
Tags
+Quote Post
Giseli Ramos
post Sep 2 2008, 11:26 AM
Post #7
More Active
Member
LV:8.5 ,8.2.1 ,8.0
QUOTE (Ton @ Sep 2 2008, 07:53 AM) *
Ton
Well, I think that have listening, because my VB program succeeded to establish a communication when I use the example TCP Communicator in the same platform (win X win). The screenshot of the example is here. It doesn't work when is Win X Linux... Strange!
Attached thumbnail(s)
Tags
+Quote Post
Scott Carlson
post Sep 2 2008, 11:58 AM
Post #8
Active
Member
Using LabVIEW Since:2005
LV:8.5.1 ,. ,.
United States Nothing Selected Nothing Selected
QUOTE (Giseli Ramos @ Sep 2 2008, 07:26 AM) *
I definitely don't think you should leave the TCP behind. This sounds more like an OS issue than a Labview issue.
#1 What Flavor of Linux are you using. (I can be more helpful smile.gif)
#2 My first suspicion is that you have a firewall blocking ports... Have you looked into this?
-Scott
Tags
+Quote Post
Giseli Ramos
post Sep 2 2008, 12:16 PM
Post #9
More Active
Member
LV:8.5 ,8.2.1 ,8.0
QUOTE (Scott Carlson @ Sep 2 2008, 08:58 AM) *
#1 What Flavor of Linux are you using. (I can be more helpful smile.gif )
-Scott
Hi Scott, I'm using Fedora 7... and I'm glad that you remembered me of the firewall issue!
On Linux, it is OK, but in Win, the firewall rules was not correctly applied... oops.gif Now it is working fine. tongue.gif
Many thanks to all and I learned some useful things in this topic such as the endian problem...
Tags
+Quote Post
Time is now: 1st December 2008 - 08:01 PM
