> Related links
Tags
> Generic file I/O error, Cannot save VI
PaulG.
post Aug 29 2008, 05:08 PM
Post #1
Member
Using LabVIEW Since:1998
LV:8.5 ,8.20 ,7.1
United States Nothing Selected Nothing Selected
I looked this up here and on the DS but have not found a solution. I keep getting a "Generic file I/O error. Cannot save VI 'xyz.VI'" From what I could glean it's network related and has been around since at least v8.0. I can go days without getting it, then one or two days out of a week I'll get it over 100 times. frusty.gif "Save as" something else is out of the question. And copying everything from the network drive to the local drive is out of the question as well. Is there a patch somewhere to fix this? It's really annoying.
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
crelf
post Aug 29 2008, 05:32 PM
Post #2
I'm a LAVA, not a fighter.
V I Engineering, Inc.
Using LabVIEW Since:1993
LV:8.5 ,. ,.
Australia United States Nothing Selected My Blog
QUOTE (PaulG. @ Aug 29 2008, 01:08 PM) *
What version of LabVIEW are you using? Can you post a VI that you're having this issue on?
Tags
+Quote Post
PaulG.
post Aug 29 2008, 07:03 PM
Post #3
Member
LV:8.5 ,8.20 ,7.1
QUOTE (crelf @ Aug 29 2008, 01:32 PM) *
Pick one. Every one I've worked on today. And it just so happens it's not doing it anymore. ohmy.gif Everyone is leaving early for the weekend so it has to be related to the office network somehow. I'll see if I can duplicate it again ... but I ain't stickin' around either. Not even for LAVA. rolleyes.gif
Tags
+Quote Post
crelf
post Aug 29 2008, 07:27 PM
Post #4
LV:8.5 ,. ,.
QUOTE (PaulG. @ Aug 29 2008, 03:03 PM) *
biggrin.gif have a great weekend. I know I will!
Tags
+Quote Post
Antoine Châlons
post Aug 31 2008, 03:16 PM
Post #5
Premium Member
Using LabVIEW Since:1999
LV:8.5.1 ,7.1.1 ,5.1
France Switzerland Spain My Gallery
QUOTE (PaulG. @ Aug 29 2008, 07:08 PM) *
Hi there,
There is a long thread on NI forum about that very anoying issue.
The issue is even worse on LabVIEW 8.5 than in 8.x but fortunately it is fixed in 8.5.1. I know no other solution than upgrading.
By the way, if you "save as", and don't change the name, it will ask you if you want to overwrite, say "yes", and most of the time it saves the VI succesfully ; weird..
Hope this helps
____________________________________________________________________________________
It's better to stay out of the rat race because if you win, you're still a rat
_____________________________________________________________________________________
Tags
+Quote Post
PaulG.
post Sep 2 2008, 08:38 PM
Post #6
Member
LV:8.5 ,8.20 ,7.1
QUOTE (Antoine Châlons @ Aug 31 2008, 11:16 AM) *
Hi there,
Hope this helps
I tried that. Didn't work. mad.gif This issue is like being nibbled to death by a duck. smile.gif
Tags
+Quote Post
Antoine Châlons
post Sep 3 2008, 05:14 AM
Post #7
Premium Member
QUOTE (PaulG. @ Sep 2 2008, 10:38 PM) *
I'm sorry it doesn't help... I know how annoying this issue is...
Apart from upgrading LabVIEW and working on a USB external hard drive and copying twice a day to the network drive until you can upgrade. I do understand it's a workaround you might not like but that's what I did during 3 month to get ride of the the ducks wink.gif
Tags
+Quote Post
PaulG.
post Sep 3 2008, 06:02 PM
Post #8
Member
LV:8.5 ,8.20 ,7.1
That's probably what I'll end up doing. It was fine this morning, but just before I started to build my application I start getting the error again. Argggggghhhh!!!!
Tags
+Quote Post
Val Brown
post Sep 3 2008, 06:04 PM
Post #9
Member
LV:8.6 ,8.5.1 ,8.2.1
Canada United States Nothing Selected
QUOTE (PaulG. @ Sep 3 2008, 11:02 AM) *
Re: your above post -- do you mean that you upgraded to 8.5.1 and that didn't make any difference?
The power of NeuroCARETM
Tags
+Quote Post
Time is now: 1st December 2008 - 10:32 PM
