Visit our LabVIEW Wiki Real Time article
Tags |
Aug 29 2008, 10:01 AM
Post
#1
![]() Very Active Member Posts: 91 Joined: 16-November 04 From: Munich, Heidelberg Member No.: 1037 Using LabVIEW Since:2005 LV:8.5 ,8.2.1 ,7.1.1
I recently learned that with an installed LabVIEW RealTime it is possible to use the RT-FIFO primitives in VIs running with Windows as target system. Are there any pitfalls when using the RT-FIFOs in a Windows application? A quick exe-build of a VI with some RT-FIFO functions ran without problems on WinXP / LabVIEW 8.6. My usecase is that we have a current project developed for RT in which the FIFOs are extensivly used (mostly for lowlvl communication in various HW driver modules). We now have a new requirement for this software to be run as stripped down version (e.g. without closed loop control) on Windows targets. It would be nice if we could keep most of the code including these with RT-FIFO. My first thought was to replace all RT-FIFOs in conditional disable structures with the queue counterparts ( Has anyone tried something like that? greetings from a warm and sunny Munich Götz
| Ad |
Post
Aug 29 2008, 01:43 PM
Post
#2
![]() Very Active Member Posts: 73 Joined: 23-March 04 From: Wallingford, CT USA Member No.: 319 Using LabVIEW Since:2001 LV:8.5.1 ,8.2.1 ,7.0
I've never seen mention of them not working in Windows. I've had zero problems using them on the host (i.e. windows) side in my applications.
| Time is now: 1st December 2008 - 11:54 PM |
