> Related links
Visit our LabVIEW Wiki Code Distribution Portal
Tags
> LV71 EXE issues with missing subVIs, Linear algebra functions are not bundled into application
Phil Duncan
post Aug 28 2008, 02:33 PM
Post #1
Member
Using LabVIEW Since:2002
LV:8.5 ,8.2.1 ,7.1.1
Australia Nothing Selected Nothing Selected
Hi all,
I have been happily developing an application in LabVIEW 7.1 (not my preferred version) that needs to be compiled into an executable. I am familiar with the app builder and the executable runs fine on the development machine. It fails to run on another PC that does not have LabVIEW installed. I built an installer to ensure the LV71 run-time engine was included. When I run the app I get "An error occured loading VI 'Real Inverse Matrix (LU).vi'. LabVIEW load error code 21.... I get the same message for a bunch of other linear algebra functions that are in the program. I am aware of many other "code 21" posts but they all seem to be related to missing items like DAQ, IMAQ etc. I have checked here and verified that there are no (listed) special requirements for linear algebra functions like the ones I am using. I have tried copying lvanlys.dll, adding the missing VI's as dynamic VI's and support files. No good.
I have noted that all the "missing" VI's are in fact included in the VI Settings tab of the app builder as shown below.
Is there a magic post that explains a very obvious solution, is there a trick that I have missed or is there some obscure reference to a work around for including linear algebra functions?
Your help is, as always, very much appreciated.
Cheers & Beers
This post has been edited by Phil Duncan: Aug 28 2008, 02:42 PM
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
crelf
post Aug 28 2008, 02:55 PM
Post #2
I'm a LAVA, not a fighter.
V I Engineering, Inc.
Using LabVIEW Since:1993
LV:8.5 ,. ,.
Australia United States Nothing Selected My Blog
Do you get any more info than just "load error code 21"? Do all of these VIs call a DLL that's missing and/or needs to be registered?
You're, of course, not right at the end of the project, right? You've subscribed to the "build early, build often" mantra, right? So this isn't a major timeline issue yet, right? wink.gif
Tags
+Quote Post
Phil Duncan
post Aug 28 2008, 04:11 PM
Post #3
Member
QUOTE (crelf @ Aug 29 2008, 12:25 AM) *
Why yes! I get a very helpful explanation. The full text reads like this: "An error occurred loading VI "Real Inverse Matrix (LU).vi". LabVIEW load error code 21: An external subroutine required for execution could not be found. frusty.gif
I get the same message for 4 other missing vi's that are all from the linear algebra palette. After clicking "OK" for each error message, I get a nice summary of all the missing VI's. mad.gif
There is no mention of unregistered or missing DLL's. This is not the same as DAQ files that must be loaded on the target machine separately, all the troublesome VI's are included in the VI settings tab of the App Builder, so LabVIEW knows they are required for the exe.
As far as I know these files call the lvanlys.dll, but it is not included in the build and I cannot force it into the build. The lvanlys.dll was put in c:\NI\Shared\LabVIEW Run-Time\7.1 directory on the target PC after installation of the executable (via installer files).
Cheers
This post has been edited by Phil Duncan: Aug 28 2008, 04:15 PM
Tags
+Quote Post
gmart
post Aug 28 2008, 05:03 PM
Post #4
NI
LV:8.0
United States Nothing Selected Nothing Selected
Analysis support is a component of the Run-Time Engine. The installer has an option to include (the default) analysis support. You could verify in the Advanced Installer settings that the "Analyze VIs Support" is checked. You could also try reinstalling just the 7.1 RTE (which I believe you can download from ni.com).
Tags
+Quote Post
crelf
post Aug 28 2008, 05:31 PM
Post #5
LV:8.5 ,. ,.
QUOTE (Phil Duncan @ Aug 28 2008, 12:11 PM) *
Ahhh - that's important - sis you enable analysis support when you installed the RTE?
EDIT: gmart got there before me smile.gif
Tags
+Quote Post
Phil Duncan
post Aug 29 2008, 03:02 AM
Post #6
Member
QUOTE (crelf @ Aug 29 2008, 03:01 AM) *
GRRRRRRRRRR I can't believe I missed that in my checks. Thanks guys, sorry for wasting your time. All is good again.
Cheers & Beers
Tags
+Quote Post
crelf
post Aug 29 2008, 02:58 PM
Post #7
LV:8.5 ,. ,.
QUOTE (Phil Duncan @ Aug 28 2008, 11:02 PM) *
Cheers & Beers
Tags
+Quote Post
Time is now: 1st December 2008 - 08:13 PM
