> Related links
Visit our LabVIEW Wiki Real Time article
Tags
> Debugging of reentrant VIs in RT
P. Rosegger
post Aug 27 2008, 05:48 PM
Post #1
Enough LAVA to be dangerous
Member
Using LabVIEW Since:2002
LV:8.20 ,8.5.1 ,.
Germany Nothing Selected Nothing Selected
Hi there,
does anyone out there have any suggestions how to debug reentrant VIs in RT? So far we couldn't figure out any feasible way...
TiA,
PR
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
neB
post Aug 27 2008, 05:50 PM
Post #2
Certified Kool-Aid Kid
Premium Member
Using LabVIEW Since:1998
LV:7.1 ,. ,.
United States Germany Nothing Selected
QUOTE (P. Rosegger @ Aug 27 2008, 01:48 PM) *
Hi there,
TiA,
PR
I'm sure I will not remember all of them but ...
Use the Hiearchy screen and do a ctrl-a to find the re-entrant VI's.
Find the re-ntrant VI on a diagram and double click it to open the FP of that instance of the re-entrant VI
Ben
Tags
+Quote Post
P. Rosegger
post Aug 28 2008, 10:54 AM
Post #3
Member
LV:8.20 ,8.5.1 ,.
QUOTE (neB @ Aug 27 2008, 07:50 PM) *
Hi neB,
thanks for your answer, which unfortunately does not work for us. I'll try to explain in detail what we were trying:
We need to load multiple instances of reentrant VIs dynamically via "Open VI Reference". As it seemed not possible in RT to place break points in reentrant VIs that are loaded dynamically we had no possibility to directly debug these VIs. Furthermore, as LabVIEW couldn't find the VIs-to-be-loaded we copied them manually to the RT system via FTP and changed the path information to have them loaded from that new location. That's why we could find no way to see wether the vi was loaded and - if it was loaded - what was going on in there.
Today we realized that in the exe creation dialogue we can define which files are to be loaded dynamically ("Source files" -> "Dynamic VIs and Support Files"). The exe creator obviously copies also those files to the RT system (at least our application worked again afterwards). The good thing about it: We're now able to open the files that are loaded dynamically in the project explorer and we're also able to debug them. The bad thing: We need to deploy those files manually after each change.
Thanks again,
PR
Tags
+Quote Post
neB
post Aug 28 2008, 11:06 AM
Post #4
Premium Member
LV:7.1 ,. ,.
Unless I mis-read you the reason they could not be found was tht they were not loaded.
A "cheap trick" that use to work was to put an instance of the dynamically called VI in a non-executing case structure so that the VIs are part of the top level app. This will forrce the dynamic VI to be deployed with the app.
Also watch your file spec since the specs change in a exe.
If you are using an invoke node, call by reference, I think you can now single step into that call and debug as normal. I also seem to remember that if you single step into multiple re-cursive calls you want to get out of all of the re-cursive calls before stopping LabVIEW to avoid a crash. (Just a friendlt warning)
Ben
Tags
+Quote Post
crelf
post Aug 28 2008, 02:48 PM
Post #5
I'm a LAVA, not a fighter.
V I Engineering, Inc.
Using LabVIEW Since:1993
LV:8.5 ,. ,.
Australia United States Nothing Selected My Blog
QUOTE (neB @ Aug 28 2008, 07:06 AM) *
Note: if you do this by wiring a constant to the case selector, this won't work when you build an app in LabVIEW 8.x (LabVIEW will strip the non-executing cases and anything that's inside them) as it folds the case structure.
Tags
+Quote Post
ragglefrock
post Aug 29 2008, 02:43 AM
Post #6
Member
LV:8.0 ,. ,.
Nothing Selected Nothing Selected Nothing Selected
QUOTE (crelf @ Aug 28 2008, 09:48 AM) *
Absolutely correct. Right thing to do now is to use a Static VI Reference.
Tags
+Quote Post
Time is now: 1st December 2008 - 07:14 PM
