Visit the LabVIEW Wiki PDA article
Tags |
Aug 25 2008, 07:37 PM
Post
#1
![]() Very Active Member Posts: 84 Joined: 23-August 07 From: now in Munich Member No.: 9210 Using LabVIEW Since:1997 LV:8.20 ,7.1 ,6.1
Hallo Leute,
Challenge: my house is full of remotes. i dont stress it enough: FULL - DVD, HIFI, TV, projector, sat receiver, computer... So I was toying with the idea of buying a universal. a worthy one (user friendly and actually doing what is needed, plus some programmed functionality) is just above my budget for the purpose (if i can manage ith LV...). and then, i have my nice Windows mobile 5 PDA, with wireless and an infrared port (granted, on the wrong side of the PDA,but who said we cant turn around the LabVIEW buttons?). So to make it run, all i need is LabVIEW PDA, (or some kind of server connection to my computer with the wireless), and the drivers for using the Infrared port as input-output device: the idea is to record the commands from the native remotes using a labview routine and DAQmx, and vice versa. But: how do i get to use the IR interface? i have heard that one can instruct LabVIEW to use mouse for example as I/O device. is it the same here? how do i do that? And also before getting into the hassle of installing LabVIEW to PDA: does it all worth it? THanks for your inputs. -------------------- ... And here's where I keep assorted lengths of wire...
| Ad |
Post
Aug 25 2008, 07:45 PM
Post
#2
Very Active JKI ![]() Posts: 145 Joined: 3-August 06 From: San Francisco, CA Member No.: 5746 Using LabVIEW Since:1996 LV:8.20 ,. ,.
And also before getting into the hassle of installing LabVIEW to PDA: does it all worth it? As long as it is your hobby/passion than it is worth it as you'll get the joy of a 'do it yourself' experience. If you are thinking it will cost less than going out and buying a 'universal remote' I think you are better off plunking the $ due to the time investment you'll inevitably make. -------------------- got VIPM?
Aug 25 2008, 07:52 PM
Post
#3
As long as it is your hobby/passion than it is worth it as you'll get the joy of a 'do it yourself' experience. If you are thinking it will cost less than going out and buying a 'universal remote' I think you are better off plunking the $ due to the time investment you'll inevitably make. I meant in the sense of "how much buggy is LabVIEW PDA"? how different is it from LabVIEW "original"? is it going to be a frustration-does-work-at-the-end project, or a fun thing that will end up nice. i am looking for your experiences as a LabVIEW PDA developer. i have never came across projects requiering PDA so... -------------------- ... And here's where I keep assorted lengths of wire...
Aug 25 2008, 07:55 PM
Post
#4
![]() CCT It Premium Member ![]() Posts: 1337 Joined: 13-June 05 From: Woerden, Netherlands Member No.: 2399 Using LabVIEW Since:2001 LV:8.5.1 ,6.1 ,8.2.1
My Blog
My Gallery
I recommend buying PDA software that allready does the task you need.
For instance TV remote controller. Here's a whole list of such apps. Ton --------------------
Aug 25 2008, 07:57 PM
Post
#5
![]() Very Active Member Posts: 61 Joined: 18-June 08 From: Ann Arbor, MI Member No.: 11790 Using LabVIEW Since:2000 LV:8.5.1 ,. ,.
My Blog
I meant in the sense of "how much buggy is LabVIEW PDA"? how different is it from LabVIEW "original"? is it going to be a frustration-does-work-at-the-end project, or a fun thing that will end up nice. i am looking for your experiences as a LabVIEW PDA developer. i have never came across projects requiering PDA so... You can buy a product called Novii Remote that will do what you are asking. Of course it isn't "DIY", but if you want something RIGHT NOW, give it a shot. -------------------- Certified LabVIEW Architect, Certified Professional Instructor
Go Blue!
Aug 26 2008, 12:12 PM
Post
#6
![]() Active Member Posts: 23 Joined: 28-July 08 From: CT Member No.: 12118 Using LabVIEW Since:2005 LV:8.5.1 ,. ,.
Hallo Leute, Challenge: my house is full of remotes. i dont stress it enough: FULL - DVD, HIFI, TV, projector, sat receiver, computer... So I was toying with the idea of buying a universal. a worthy one (user friendly and actually doing what is needed, plus some programmed functionality) is just above my budget for the purpose (if i can manage ith LV...). and then, i have my nice Windows mobile 5 PDA, with wireless and an infrared port (granted, on the wrong side of the PDA,but who said we cant turn around the LabVIEW buttons?). So to make it run, all i need is LabVIEW PDA, (or some kind of server connection to my computer with the wireless), and the drivers for using the Infrared port as input-output device: the idea is to record the commands from the native remotes using a labview routine and DAQmx, and vice versa. But: how do i get to use the IR interface? i have heard that one can instruct LabVIEW to use mouse for example as I/O device. is it the same here? how do i do that? And also before getting into the hassle of installing LabVIEW to PDA: does it all worth it? THanks for your inputs. I am not sure about the IR interface, but have you looked at the Price Point for Labview PDA Module? That would be an expensive Universal Remote!! (Fun project though)
Aug 26 2008, 04:31 PM
Post
#7
![]() Extwemely Active Premium Member ![]() Posts: 1632 Joined: 23-January 05 From: Here Member No.: 1431 Using LabVIEW Since:2003 LV:8.6 ,7.0 ,.
As mentioned, the PDA module (and licenses, although I think you don't need one if you only have one copy) is expensive. Additionally, I haven't worked with the recent versions of the module, but you should still expect it to be buggy. In the past, it was often "code something, test it, and then spend quite a bit of time finding and working around the PDA module bugs, some of which will be highly unexpected". I assume it's still more or less the same.
I believe you should be able to use the IR port using the IrDA functions or as a serial port, but I never tried, so I can't tell. The documentation for the module can probably give you the answer. All in all, I would go with the others' suggestion of using a real remote or proper software. -------------------- More than meets the eye...
Aug 26 2008, 06:26 PM
Post
#8
thanks guys for your input. as gar as licence goes, i have the module here with mine. dont intend to distribute.
All in all, I would go with the others' suggestion of using a real remote or proper software. i guess so. would be stupid to reinvent the weel, even with LV. yet i will try to talk to the IR port via NI-daq, see if i can get something usefull. -------------------- ... And here's where I keep assorted lengths of wire...
Aug 26 2008, 07:02 PM
Post
#9
![]() I'm a LAVA, not a fighter. V I Engineering, Inc. ![]() Posts: 3751 Joined: 13-October 03 From: Michigan, USA Member No.: 181 Using LabVIEW Since:1993 LV:8.5 ,. ,.
My Blog
i will try to talk to the IR port via NI-daq, see if i can get something usefull. You'll probably want to use NI-VISA instead of NI-DAQ. -------------------- ![]()
| Time is now: 2nd December 2008 - 12:59 AM |
