> Related links
Visit our LabVIEW Wiki Code Distribution Portal
Tags
> Building GOOP application, Building GOOP application
Rammer
post Aug 22 2008, 06:48 PM
Post #1
I want a LabVIEW icon under my name!
Member
Using LabVIEW Since:1998
LV:8.5 ,8.2.1 ,.
United States United States Nothing Selected
I am trying to build an application that has many GOOP classes. It copies the object references for each class under the build directory within the object name. However when the EXE runs it asks me to find each objectreference.ctl. How do I get around this?
Rammer
Found a fix. I created a separate project with all the object references included and it builds just fine. I was not directly including the .lvclass file for some of the objects I store in my userlib. Once I did this it seems to like it. Not sure why it is not just found through the dependancy chain.
Rammer
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
crelf
post Aug 22 2008, 08:54 PM
Post #2
I'm a LAVA, not a fighter.
V I Engineering, Inc.
Using LabVIEW Since:1993
LV:8.5 ,. ,.
Australia United States Nothing Selected My Blog
QUOTE (Rammer @ Aug 22 2008, 02:48 PM) *
Are you sure it's GOOP? Or is it LVOOP, dgGOOP, OpenGOOP...?
I was not directly including the .lvclass file...
OK - it's LVOOP. Just so you know, GOOP and LVOOP are not interchangable terms.
Tags
+Quote Post
Time is now: 1st December 2008 - 06:43 PM
