Tags |
Aug 21 2008, 04:32 PM
Post
#1
I've come back for more. Member Posts: 2 Joined: 21-August 08 Member No.: 12333 Using LabVIEW Since:2005 LV:7.1 ,8.5 ,8.0
Hi guys
Please help. I've created a test report where I add the Start date & time and the Finish date & time by converting the time stamp value to a date & time string with the function 'Get Date/Time String'. I want to calculate the test in progress time, start to finish. I have a mental blank, can I do this in Labview? All help much appreciated.
| Ad |
Post
Aug 21 2008, 04:48 PM
Post
#2
![]() Very Active Premium Member ![]() Posts: 217 Joined: 31-January 03 From: Wilson NC USA Member No.: 48 Using LabVIEW Since:2001 LV:8.5 ,. ,.
Hi guys Please help. I've created a test report where I add the Start date & time and the Finish date & time by converting the time stamp value to a date & time string with the function 'Get Date/Time String'. I want to calculate the test in progress time, start to finish. I have a mental blank, can I do this in Labview? All help much appreciated. If you just subtract one from the other the time stamp is coerced to seconds and the result is in seconds. -------------------- Michael E. Ross
Senior Design Engineer Standard Motor Products, Inc. 2717 Commerce Road Wilson, NC 27893 mross@smpcorp.com 252.234.5821
Aug 22 2008, 02:10 PM
Post
#3
If you just subtract one from the other the time stamp is coerced to seconds and the result is in seconds. Many thanks I really appreciate your reply. A simple solution that works. Cheers.
| Time is now: 1st December 2008 - 11:37 PM |
