Tags |
Aug 20 2008, 10:48 PM
Post
#1
Active Member Posts: 15 Joined: 12-October 05 Member No.: 3209 Using LabVIEW Since:1997 LV:8.20 ,8.0 ,7.1
In my data acquisition system
I need absolute time references with about 1 ms accuracy. I first developed some code under Linux Fedora7 and the LabVIEW built-in time function was accurate enough for my application. When I use the same code under WinXP32 (running on the same hardware!) however I do not get better than about 15 ms. I did try LabVIEW 7.1, 8.0 and 8.2: same result. Is it a Win32 API problem? Is there any known way to get absolute timestamps under WinXP32 with 1 ms accuracy? The LabVIEW timer seems accurate enough: is there an accurate and reliable way to convert timer ticks to absolute time? And what about the use of the Windows API function "QueryPerformanceCounter" to get even more accurate ticks? Thanks G
| Ad |
Post
Aug 20 2008, 11:06 PM
Post
#2
![]() Very Active Premium Member ![]() Posts: 217 Joined: 31-January 03 From: Wilson NC USA Member No.: 48 Using LabVIEW Since:2001 LV:8.5 ,. ,.
This is a complicated subject. How absolute do you want absolute to be?
a) NIST traceable? b) How about better than 1ms relative to the original start time and and start time is nailed down and tracable? c)Or maybe just really precise with respect to the start time, but the start time could be off a few ms? Each of these offers some solace from the fact that a PC is really crap for keeping "good" time. Whatever good means. heh heh A not too difficult relative but precise method [c)] would be to get the timestamp and start a counter timer, getting the timer count for the events of interest. The timer can run 20MHZ accurately so to the extent that you trust the first time stamp and its relationship to the starting of the timer you have a very good idea when each of the events occured and can easily add them to the time stamp for a pseudo absolute time. I love that, "pseudo absolute." Really, any DAQ card acquisition is keeping pretty good relative time, it is just a matter of, when exactly did it start? All you have to do is digitize the signal and calculate the time from the start. It is a very good idea to be sure this isn't good enough for your purposes before getting involved in the alternatives. Some of the alternatives are a pain in the butt. If you explain more the brains here can do a better job of explaing the trickier ways to do this. -------------------- Michael E. Ross
Senior Design Engineer Standard Motor Products, Inc. 2717 Commerce Road Wilson, NC 27893 mross@smpcorp.com 252.234.5821
Aug 21 2008, 12:42 AM
Post
#3
Thanks Michael for your reply
... If you explain more the brains here can do a better job of explaing the trickier ways to do this. OK, I'll try to better focus on what I actually need ... b) How about better than 1ms relative to the original start time and and start time is nailed down and tracable? ... The b) scenario corresponds to my case. My data stream must be synchronized to some other data, provided by another piece of hardware, and the sync is done by matching the two timelines. The data stream is not continuous but in a sequence of data packages, triggered by an external hardware device. Some numbers: 120 AI sampled at 500 Hz, 220 ms package, and about 40 ms pause between packages. For each package I need at least one absolute timestamp: the other 109 timestamps are at 2 ms regular interval. ... you trust the first time stamp and its relationship to the starting of the timer you have a very good idea when each of the events occured and can easily add them to the time stamp for a pseudo absolute time. I love that, "pseudo absolute." ... Exactly: I trust the clock of my DAQ hardware, I know the sample rate therefore I have no problem to know the relative timestamps with an accuracy that is enough for my application. The problem is to have at least 1 absolute accurate (1 ms) time reference with a well known (again 1 ms accuracy) relationship to my time series. In the past, I did use IRIG-B time code given by the station GPS clock (decoded by a PCI board) to get the absolute time. However, I found that under Linux Fedora7 + LabVIEW 8.2 + NI-DAQmx 8.0 I can use the LabVIEW built-in time function to get a "pseudo-absolute" timestamp which is "absolute" enough for my application (as long as the ntpd server is running and properly working.) For some other reason, I was forced to move to WinXP32 and surprisingly I do not get the same accuracy anymore (at least a factor 10 worse) although using exactly the same hardware. I really would like to get rid of that IRIG-B board and under Linux it was actually possible. Questions: a) how to produce 1 ms accuracy absolute timestamps under WinXP32 without using additional/specific hardware? b) why is the LabVIEW built-in time function a factor of 10 worse under WinXP32? Thanks G
Aug 21 2008, 01:07 PM
Post
#4
![]() Extwemely Active Premium Member ![]() Posts: 1632 Joined: 23-January 05 From: Here Member No.: 1431 Using LabVIEW Since:2003 LV:8.6 ,7.0 ,.
The resolution of the get time primitive in Windows is ~16 ms. I'm not sure why, but I don't think you can change that.
If you want to get ms values, you can use the tick count primitive, which returns the number of ms since the OS was started (U32, so it wraps after ~49 days). You can wrap it in a functional global, so it would remember the timestamp when it started and would do the calculation itself. If you want higher accuracy, you can call the queryperformancecounter API function for a microsecond resolution, but unless you can sync it correctly, I doubt it would help you. -------------------- More than meets the eye...
Aug 21 2008, 02:29 PM
Post
#5
OK. I think you cannot do this without hardware in your PC to get the tracable timestamp. Then you have to synchronize it with the triggering of the acquisition. This is not so easy as far as I know. It would be better if you could take all channels of data using one system or the other.
If you use a buffered (not continuous) acquisistion this can be triggered externally (like an osciloscope). If you know the timestamp of the trigger pulse then you can count on the timestamp (to better than 1ms resolution) being the start time of the acquisition. Even if your two different signals and sources have different starting tmestamps you can still synchronize the data after the acquisitions are complete. Even if the acquisition rates are different you can use and xy graoh to show them together. I have seen discussions of this business with the absolute timestamp, but I have never done it myself. It is a difficult complication that I have tried hard to avoid. PCs are bad about timing that is why there is some much function on the DAQ cards themselves. If more than one DAQ card or system is used and close synchronization is needed it takes quite a bit of extra care. mike -------------------- Michael E. Ross
Aug 24 2008, 12:47 AM
Post
#6
Here I am again,
Yair, Michael, thanks for your replies. The resolution of the get time primitive in Windows is ~16 ms. I'm not sure why, but I don't think you can change that. ... No way to change that, I know. I also tried calling directly the Win API GetSystemTime but I get exactly the same accuracy (~16 ms), I guess it is a Win limitation. I can tell you that under Fedora 7 I didn't have problems to get ~1 ms accuracy, same code, same LabVIEW functions. If you want to get ms values, you can use the tick count primitive ... Do you know an easy way to get absolute time from the tick counter? I did it in the following (definitely not easy) way: 1) in the initialization part of my code I use a loop to collect absolute timestamps and timer counts, (hopefully) simultaneously, for a few seconds at a few ms intervals: it produces two arrays of some-1000 elements, one has the timer ticks, the other one the corresponding absolute timestamps. 2) I then use the linear fit function to define the linear relationship between the two arrays. Although the absolute values have 10-20 ms accuracy, on the average over a few seconds they well represent the actual absolute time sequence. 3) in the main part of the code, then, I only use the tick counter and the previously defined linear relatioship to calculate the absolute time corresponding to timer ticks. I get absolute timestamps, with ~1 ms accuracy, very close to be correct, although I found a small offset (<2 ms) which is constant during execution but changes from one run to the other If you want higher accuracy, you can call the queryperformancecounter API function for a microsecond resolution, but unless you can sync it correctly, I doubt it would help you. I already wrote some code to use the QPC API, it works great. I'm going to try it with the same synchronization procedure described above for the LabVIEW timer. OK. I think you cannot do this without hardware in your PC to get the tracable timestamp. Then you have to synchronize it with the triggering of the acquisition. This is not so easy as far as I know. ... That's the way I did it in the past, with the help of this PCI module which needs to be conected to the station GPS clock and uses the external hardware trigger to latch the event time with 100 ns resolution. Kind of increases the complexity of the system I'd be happy to get rid of it... I have seen discussions of this business with the absolute timestamp, but I have never done it myself. It is a difficult complication that I have tried hard to avoid. I'm going to do some more tests of the synchronized QPC, then I'll post here some code to show you how it works, get your feedback and possibly improve it. Thanks again for your attention, G
Aug 24 2008, 12:59 PM
Post
#7
Do you know an easy way to get absolute time from the tick counter? I did it in the following (definitely not easy) way: The attached example (8.0) has simpler logic, but you should note that it does not handle the U32 rollover. In any case, you can't expect to get ms accuracy in a desktop OS. While the CPU is certainly capable of it, the OS is not designed to guarantee it. If you expect to get synchronization in more than one machine, I think you will have to use some external triggering or even a real time OS.
Attached File(s)
Aug 30 2008, 03:50 AM
Post
#8
The attached example (8.0) has simpler logic, but you should note that it does not handle the U32 rollover. ... Hi Yair, thank you very much for your contribution. Unfortunately, your VI is a bit too simple: what I need is a time generator with about 1 ms accuracy AND ALSO <1 ms absolute error from a traceable source. Your VI is the simplest way to merge absolute time with accurate timer ticks. However, we know that the absolute time comes with a 10-20 ms error, therefore the following time stream, although produced using the timer (1 ms relative accuracy) will be affected by that error and the error will change from one call to another (inside a +/- 15.6 ms interval.) This makes the time series unreliable external absolute time sources like GPS time.) In any case, you can't expect to get ms accuracy in a desktop OS. While the CPU is certainly capable of it, the OS is not designed to guarantee it. ... I agree with you as long as we only talk about Win32. I can tell you that under Linux + ntpd server properly running you can get better than 1 ms simply using the LabVIEW built-in time function. What I actually wonder is if there is any (simple) way to get 1 ms accurate AND reliable timstamps under Win32 as I get under Linux (from exactly the same hardware!) I attach my last test VI (8.0) which gives about 1 ms accuracy absolute time, using the QPC timer and converting it to absolute time by using an ad-hoc relationship (does not handle the rollover.) [ Main: test_QPC_absolute_time.vi SubVIs: qpc_timer.vi qpc_absolute_timer.vi ] It's not elegant but I think it does the job: in the end we get accurate+absolute timestamps. Obviously, it's a starting point and can be improved, please let me know your opinion and any comment/suggestion. Thanks, G
Attached File(s)
test_QPC_absolute_time.vi ( 111.51K )
qpc_timer.vi ( 101.04K )
qpc_absolute_time.vi ( 10.78K )
Aug 30 2008, 01:58 PM
Post
#9
... [ Main: test_QPC_absolute_time.vi SubVIs: qpc_timer.vi qpc_absolute_timer.vi ] ... Forgot to attach "processor_speed.vi" subVI [ Main: test_QPC_absolute_time.vi SubVIs: processor_speed.vi qpc_timer.vi qpc_absolute_timer.vi ] G
Attached File(s)
Aug 31 2008, 06:27 PM
Post
#10
I will start by saying that I have zero knowledge about this, so everything below may be wrong, but since you asked:
AND ALSO <1 ms absolute error from a traceable source. I'm not sure if you can do that reliably without dedicated hardware, even on Linux. QUOTE However, we know that the absolute time comes with a 10-20 ms error Maybe YOU know it. I only see that the displayed resolution is ~16 ms. I know nothing about the accuracy (maybe it's synchronized with sub-ms accuracy?). QUOTE I can tell you that under Linux + ntpd server properly running you can get better than 1 ms simply using the LabVIEW built-in time function. But can you trust it to be synchornized? Regarding your code, I can't say much, since I didn't dive into it, but I can comment on a couple of things: The local is unnecessary and causes a race condition. It can be read before its indicator is written to. You can just get rid of it and wire the data straight into the loop. Building arrays in loops is a big no-no as it requires repeated calls for memory allocation and can hurt performance and statistics, especially when trying to time code. When you want to distribute code, it's better if you do a save as and create an LLB, as it's then a single file. -------------------- More than meets the eye...
Aug 31 2008, 09:32 PM
Post
#11
Hi Yair,
thanks for your answer I'm not sure if you can do that reliably without dedicated hardware, even on Linux. ... But can you trust it to be synchornized? I did it, I can tell you that when the ntpd is properly running (not only correctly configured but also well in sync with the external ntp server) the LabVIEW built-in time function gives accurate absolute timestamps, at least accurate enough for my application (better than 1 ms.) ... Maybe YOU know it. I only see that the displayed resolution is ~16 ms. I know nothing about the accuracy (maybe it's synchronized with sub-ms accuracy?). Ops, you're completely right, I didn't think about it, the two output (absolue time and timer) could actually be internally synchronized, I don't know either. My worry is only that the time series produced using the timer will be shifted by the amount of the error of the first absolute timestamp. ... The local is unnecessary... wire the data straight into the loop. ... Yes, of course, it's only an example in a test program. I did use the local only to show that the following main loop (where the new absolute timestamps are generated) can be completely disconnected from the first part. It only needs a few numbers that can be passed using a local. Building arrays in loops is a big no-no as it requires repeated calls for memory allocation and can hurt performance and statistics, especially when trying to time code. I see your point, what do you suggest, then? When you want to distribute code, it's better if you do a save as and create an LLB, as it's then a single file. Sorry, I am the only direct user of my applications, I'm not used to distribute my code. Next time I'll use a LLB. Anyways, I have some bad news. I found that there is always a drift between the absolute time generated by the LabVIEW built-in function and the absolute time generated with my code. My explanation is that the error in the determination of the parameters of the linear relationship, although very small, on the long run can produce a large time error (I got 50 ms over one hour.) Another explanation is that only the PC clock is drifting (after all, 50 ms/h = 1.2 s/day only) but at the moment I have no way to verify this. In other words, I will probably give up and go back to the hardware solution, using the IRIG-B code from the local GPS clock. G
Sep 1 2008, 04:05 PM
Post
#12
![]() I'm a LAVA, not a fighter. V I Engineering, Inc. ![]() Posts: 3751 Joined: 13-October 03 From: Michigan, USA Member No.: 181 Using LabVIEW Since:1993 LV:8.5 ,. ,.
My Blog
When you want to distribute code, it's better if you do a save as and create an LLB, as it's then a single file. -------------------- ![]() |
