> Related links
Visit our LabVIEW Wiki Code Distribution Portal
Tags
> LabVIEW NT Service and OOP Collide?!, Overwrite VIs avoid service start?
Milchbilch
post Aug 20 2008, 04:06 PM
Post #1
5 more posts to go!
Member
Using LabVIEW Since:2000
LV:8.20 ,. ,.
Nothing Selected Nothing Selected Nothing Selected
Hi all!
I succesfully could build system services out of LabVIEW Applications using srvany and instsrv in the past.
Now I get problems when I use classes with overwrite VIs:
They do have the same name so the name conflict is solved by the AppBuilder by copying the VIs with the same names to different subfolders. I can start the exe that is built this way.
But I cannot start the service I created!
I always get "Error 1053: The service did not respond to the start or control request in a timely fashion"
I guess this is due to not beeing able to load the VIs from the subfolders. But I am not sure.
I made a very easy VI to test it: Containig only 2 VIs with the same name, building the exe, (subfolders are created), exe can be started, created service succesfully, ERROR 1053 when starting the service!
I do not know how to solve this. I mean I really do need overwrite VIs and i do need the App to run as a service!
Any help is really appreciated.
Best regards,
Stefan
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Aristos Queue
post Aug 20 2008, 04:18 PM
Post #2
LV R&D Envoy
NI
LV:8.5.1 ,. ,.
United States Nothing Selected Nothing Selected My Gallery
Can you please repost this topic over on ni.com here so that AEs can investigate it? If there is a bug that needs to be addressed, that's the best way to get it started.
"A VI outside a class is a gun without a safety. Data outside a class is a target."
--- A message from LabVOOP R&D
Tags
+Quote Post
pdc
post Aug 20 2008, 04:48 PM
Post #3
Member
Using LabVIEW Since:1997
LV:8.5.1 ,8.2.1 ,6.1
Canada ca_quebec Nothing Selected
I currently have an application running as a service using srvany and overrided VIs. So it's possible.
The only difference with your problem description is the way I manage the overrided VIs. For this application I manually configure the application builder to save classes as a different .llb file instead of letting it copy the file in different directories.
This application is build with LV8.5 but if my memory serves, I did the same thing with LV8.2.
Tags
+Quote Post
Milchbilch
post Aug 20 2008, 05:19 PM
Post #4
5 more posts to go!
Member
LV:8.20 ,. ,.
Thank You fro replying that fast!
QUOTE (pdc @ Aug 20 2008, 06:48 PM) *
Hmmm... Knowing that - i retried to do the whole thing and guess what - Now it works!
I do not know what I did wrong this afternoon. I tried to create this service about 20 times, always successful but it could not be started. So I created another easy Test service without overwriting VIs. It worked so I thought I'd found the problem. However.
That is generally a good idea I guess. I will do that in the future. Though I do not know how to, yet.
I guess it's an option in the build specifications, right?
Time to go home now. Thanks again!
Stefan
Tags
+Quote Post
pdc
post Aug 20 2008, 06:21 PM
Post #5
Member
QUOTE (Milchbilch @ Aug 20 2008, 01:19 PM) *
I would like to say it's just a checkbox, but it's not.
In the application builder you have to create multiple Destination with the destination type = LLB. Than, in the source file settings, you can associate VIs, libraries, classes or directories to a custom destination by clicking "Set destination for all contained items".
It's not so hard if the project is well organized.
Tags
+Quote Post
Time is now: 2nd December 2008 - 12:19 AM
