Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Aug 19 2008, 02:06 PM
Post
#1
One hit wonder! Member Posts: 1 Joined: 5-August 08 Member No.: 12203 Using LabVIEW Since:2008 LV:8.5.1 ,. ,.
In developing a diagnostic medical device (similar to a hearing test) that uses pulsed sounds one has to create fade in and fade out.
WHY?? Because if you start and stop a sound a headset and it is stripped of file formating so all it is is a sound wave the speaker POPS! The way to avoid this is to create a .5 - 1 second fade in where you linearly increase the amplitude of the wave. Here is my problem, I'm using a while loop to create the desired sound pulse and ramp up. The loop is not looping fast enough to produce a nice smooth fade in, the steps are too large. The only way to make smaller steps would be to increase the length of time the fade in takes place. Any suggestions? This post has been edited by crewex: Aug 19 2008, 02:07 PM
Attached File(s)
| Ad |
Post
Aug 19 2008, 03:01 PM
Post
#2
![]() Very Active NI ![]() Posts: 110 Joined: 28-October 05 From: Austin, TX Member No.: 3370 Using LabVIEW Since:1993 LV:8.5.1 ,8.2.1 ,8.6
My Gallery
You'll want to use a second simple waveform (ramp up, ramp down) to scale your actual signal. So rather than varying the amplitude of the signal generator, use a constant amplitude and then scale the generated waveform by multiplying it by the ramp waveform.
Here's a partial solution showing how to generate a ramp up and using it to scale your sine signal. This will ramp up continuously so you'll need to figure out how to stop the ramp and keep it level at your final amplitude and then add the ramp down for the end of your signal. -------------------- Christian L
NI Systems Engineering - Real-Time and Embedded Control Technologies "I like my G code neat."
Aug 19 2008, 05:23 PM
Post
#3
![]() Very Active Member Posts: 200 Joined: 6-March 05 From: Mountain View, CA Member No.: 1764 Using LabVIEW Since:1994 LV:8.5 ,. ,.
You'll want to use a second simple waveform (ramp up, ramp down) to scale your actual signal. So rather than varying the amplitude of the signal generator, use a constant amplitude and then scale the generated waveform by multiplying it by the ramp waveform. The Windowing functions are also commonly used for this purpose. (Palettes -> Signal Processing -> Windows) Cosine window is pretty good. It's easier than a ramp because you don't have to calculate the starting and stopping. It gets trickier if you signal spans mulitple iterations of the loop, and if you can't pre-generate the whole signal at once, but it doesn't seem like you are in that situation.
| Time is now: 1st December 2008 - 07:04 PM |
