> Related links
Tags
> speed control
electrika
post Aug 18 2008, 05:05 PM
Post #1
2 more posts to go!
Member
Using LabVIEW Since:2008
LV:8.5.1 ,. ,.
Nothing Selected Nothing Selected Nothing Selected
I am trying to control the speed of a 3-axes system which controls the motion of a tool in the three directions. How can I control the velocity of this tool? I have an existing labview program to do this. But need to be able to change the velocity with which the tool moves. Is it possible to do this?
Thank you for your attention.
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
TobyD
post Aug 18 2008, 05:13 PM
Post #2
Premium Member
Using LabVIEW Since:2007
LV:8.6 ,8.5.1 ,8.2.1
United States Italy Nothing Selected
QUOTE (electrika @ Aug 18 2008, 10:05 AM) *
We are going to need a lot more information. It is difficult to answer your question without knowing what you are controlling, what are you controlling it with (hardware used), what have you already tried, etc. Post your code so we can see what you are working with.
Tags
+Quote Post
crelf
post Aug 18 2008, 05:25 PM
Post #3
I'm a LAVA, not a fighter.
V I Engineering, Inc.
Using LabVIEW Since:1993
LV:8.5 ,. ,.
Australia United States Nothing Selected My Blog
QUOTE (electrika @ Aug 18 2008, 01:05 PM) *
QUOTE (TobyD @ Aug 18 2008, 01:13 PM) *
I agree with TobyD, but you might want to have a look at the NI motion pages to start with.
Tags
+Quote Post
martin@aerodynam...
post Aug 19 2008, 08:17 AM
Post #4
Premium Member
Using LabVIEW Since:1998
LV:8.20 ,8.0.1 ,7.1.1
Switzerland Switzerland Switzerland
QUOTE (electrika @ Aug 18 2008, 07:05 PM) *
I control multiple axis, but as already told we need to know more about your hardware / software used to help you...
do you use a NI-Motion Controller?
in which mode does he opperate absolute/relative contouring, position mode, or whateve?
if you change the speed you could get problems with your system (it can become instable..)
Happy Wiring! (User defined "Swiss Wire Class" for neutral data only!!!)
Tags
+Quote Post
electrika
post Aug 20 2008, 03:23 PM
Post #5
2 more posts to go!
Member
LV:8.5.1 ,. ,.
I use a Newport PM500C Precision Motion Controller....actually the Z motion of the system has a feed back system, there is a digital balance kept below and I am trying to maintain a constant(specified) weight. But the speed with which the motor moves down is different for different specified weights. But now I want to maintain a constant speed of the Z axis throughout irrespective of the weight specifed.
I am thinking that an open loop will work for me in this case but I am not sure if it will affect the system stability.
Sorry for a delayed reply. I hope you guys can still help me with this.
Thanks.
QUOTE (martin@aerodynamics @ Aug 19 2008, 08:17 AM) *
Tags
+Quote Post
electrika
post Aug 20 2008, 05:04 PM
Post #6
2 more posts to go!
Member
LV:8.5.1 ,. ,.
This is the code for the feedback loop! Hope that will help.
Attached File(s)
Tags
+Quote Post
martin@aerodynam...
post Aug 21 2008, 07:08 AM
Post #7
Premium Member
QUOTE (electrika @ Aug 20 2008, 07:04 PM) *
can you post your vi?
or at least a picture of the blockdiagramm from your "G" vi...
Tags
+Quote Post
electrika
post Aug 21 2008, 04:34 PM
Post #8
2 more posts to go!
Member
LV:8.5.1 ,. ,.
QUOTE (martin@aerodynamics @ Aug 21 2008, 07:08 AM) *
Sorry ....here it is.
Attached thumbnail(s)
Tags
+Quote Post
Time is now: 1st December 2008 - 09:36 PM
