Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Aug 17 2008, 09:17 PM
Post
#1
Active Member Posts: 15 Joined: 1-August 05 From: Austin, TX Member No.: 2672 Using LabVIEW Since:1995 LV:8.2.1 ,6.1 ,4.1
I'm going through a first pass of upgrading our applications to 8.6 using the NI Labs VIA tool. So far, so good but I'd like to dump the current "Error List" LabVIEW 8.6 is complaining about. Does anyone know if this list can be dumped to file via the clipboard? The dialog is not consistent with the the LabVIEW "Find" dialog, thats allows content to be cut and pasted.
-Chroma
| Ad |
Post
Aug 18 2008, 02:38 AM
Post
#2
Very Active NI ![]() Posts: 213 Joined: 14-March 06 From: Austin, TX Member No.: 4441 Using LabVIEW Since:1999 LV:8.6 ,8.5 ,8.0
I'm going through a first pass of upgrading our applications to 8.6 using the NI Labs VIA tool. So far, so good but I'd like to dump the current "Error List" LabVIEW 8.6 is complaining about. Does anyone know if this list can be dumped to file via the clipboard? The dialog is not consistent with the the LabVIEW "Find" dialog, thats allows content to be cut and pasted. What "Error List" are you talking about? Can you attach a screenshot? -D
Aug 18 2008, 05:42 PM
Post
#3
What "Error List" are you talking about? Can you attach a screenshot? -D The standard error list dialog. See attached. -Chroma
Attached image(s)
Aug 18 2008, 07:14 PM
Post
#4
The standard error list dialog. See attached. Thanks for the clarification. Unfortunately, there is currently no way to export the Error List contents. It does seem like a useful suggestion, though...I recommend you submit this idea to the Product Suggestion Center. -D P.S. - I'm also curious about the broken VIs...were they unbroken in 8.5, but broken in 8.6? What specifically is wrong on their diagrams? Are there toolkits you have installed in 8.5 that you don't have installed in 8.6?
Aug 18 2008, 08:13 PM
Post
#5
Thanks for the clarification. Unfortunately, there is currently no way to export the Error List contents. It does seem like a useful suggestion, though...I recommend you submit this idea to the Product Suggestion Center. -D P.S. - I'm also curious about the broken VIs...were they unbroken in 8.5, but broken in 8.6? What specifically is wrong on their diagrams? Are there toolkits you have installed in 8.5 that you don't have installed in 8.6? I deleted some wires in the Temp Sys Demo (8.2.1) top level and some sub-VIs, that's all. -Chroma
Aug 19 2008, 12:04 AM
Post
#6
![]() Confucius say: Crowded elevator always smell different to midget Admin ![]() Posts: 2367 Joined: 13-October 02 From: Planet Earth Member No.: 2 Using LabVIEW Since:1994 LV:8.5 ,8.2.1 ,7.1.1
My Blog
My Gallery
Ya, I guess exporting to a text file or clipboard may be useful to somebody. Can you explain the usefulness of this list outside of LabVIEW? The whole idea of this list is to double-click the highlighted error item and it automatically takes you to the location with the problem.
Other than some corporate documentation policy, I don't see what other use it may have. --------------------
Aug 19 2008, 01:47 AM
Post
#7
![]() Extremely Active Premium Member ![]() Posts: 595 Joined: 8-December 03 From: Dallas, Texas Member No.: 208 Using LabVIEW Since:2000 LV:8.6 ,8.2.1 ,7.1.1
My Gallery
Well the situation that we just had recently was in an executable that had issues w/ missing VIs for plugins that were not distributed w/ the EXE.
W/ out the text from the error window, it's extremely tricky to try to determine what's missing(legally that is). Also if you were working in a framework environment that other ppl used your code and there was a problem due to dynamic loading in general, it would be nice to send out the text of the error to yourself so you don't need some non programmer trying to figure out what this all means. That's about all I got for now. Not solid but viable -------------------- Norman J. Kirchner Jr.
Automation Software Engineer ~,~ The Captain Was Here Premium Blend ![]()
Aug 19 2008, 03:04 PM
Post
#8
![]() Extremely Active Member Posts: 509 Joined: 2-August 05 Member No.: 2680 Using LabVIEW Since:1996 LV:8.5.1 ,8.6 ,.
Also if you were working in a framework environment that other ppl used your code and there was a problem due to dynamic loading in general, it would be nice to send out the text of the error to yourself so you don't need some non programmer trying to figure out what this all means. For code used by our customers, I always incorporate a VI at the end that silently writes the error, date, time, and the error message to a file in an automatic folder C:\Errors. Since I work with Vision, I also save the offending image with an error#-date-time file name. For some reason Vision VI's are not very good at displaying their call-chain, so I usually add a chain showing which Vi, and state in the state-machine the error occurred. I also add the ability to log individual states in every state-machine to debug problems but I have never needed to use this at a customer install. Neville
| Time is now: 1st December 2008 - 10:21 PM |
