> Related links
Visit our LabVIEW Wiki Real Time article
Tags
> Installing LV RT 8.5.1 (PharLab) under VMware?
Götz Becker
post Aug 14 2008, 06:33 AM
Post #1
Member
Using LabVIEW Since:2005
LV:8.5 ,8.2.1 ,7.1.1
Germany ger_baden ger_bavaria
is it possible to install LabVIEW RT under VMware? My thought usecase would be programming on my notebook for RT (without carrying a PXI around). I wouldn´t expect to test any time critical stuff, but running some general code should be possible.
Any ideas?
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
jgcode
post Aug 14 2008, 06:47 AM
Post #2
Premium Member
Using LabVIEW Since:2006
LV:8.5.1 ,8.6 ,.
Australia Poland Nothing Selected
Great question...have no idea tho!
The below is for a desktop to a RT. You would need a license for Pharlap or Vxworks tho.
Requirements for a Desktop PC as a Real-Time Target
Cool if it did work....
all day...
Tags
+Quote Post
Neville D
post Aug 14 2008, 06:06 PM
Post #3
Member
Using LabVIEW Since:1996
LV:8.5.1 ,8.6 ,.
Canada Nothing Selected Nothing Selected
Do you want to run RT code or develop RT code?
Neville.
Tags
+Quote Post
Götz Becker
post Aug 14 2008, 07:44 PM
Post #4
Member
QUOTE (Neville D @ Aug 14 2008, 08:06 PM) *
Neville.
Run code in the sense of trying concepts with RT only functions and doing tests with RT apps (no timing related tests) like file load/save or communication to a host app.
Tags
+Quote Post
Neville D
post Aug 14 2008, 09:40 PM
Post #5
Member
LV:8.5.1 ,8.6 ,.
QUOTE (Götz Becker @ Aug 14 2008, 12:44 PM) *
Run code in the sense of trying concepts with RT only functions and doing tests with RT apps (no timing related tests) like file load/save.
There are very few functions that are RT-only. Even these usually have a non-RT equivalent, so there is not much to try out.
You could always write code that is supposed to run on RT and then run it on Windows (or other). RT is a subset of Windows capabilities.
The only areas where this wouldn't work out perfectly is if you want to check out speed. Execution time on RT may be more "deterministic" or the Symmetric Multiprocessing might work out better on that platform. Another area is if there are bugs on one platform that are not on the other.
As to whether you can do what you want with VMware etc, I don't think so. Easiest bet is to buy a LV-RT runtime licence, get a cheap PC that conforms to the requirements for LV-RT, load it on and treat that as your RT target. But like I said, your better off testing functionality in a non-Rt platform.
Neville.
Tags
+Quote Post
jgcode
post Aug 14 2008, 11:45 PM
Post #6
Premium Member
LV:8.5.1 ,8.6 ,.
QUOTE (Neville D @ Aug 15 2008, 05:40 AM) *
This is a good point.
I guess when you deploy to RT you are looking to debug anything problems with the build running headless versus the dev environment.
And anything specifc to RT is probably related to hardware (e.g. cFP - dipswitches, lights, IO) and so unless you mimic your hardware there is probably not much point and you are better coding in Windows.
Still a cool idea tho....
all day...
Tags
+Quote Post
Time is now: 1st December 2008 - 06:36 PM
