Check out the related Code Repository Files or visit the LabVIEW Wiki Development Environment Portal
Tags |
Aug 13 2008, 02:00 PM
Post
#1
I've come back for more. Member Posts: 2 Joined: 15-May 08 Member No.: 11510 Using LabVIEW Since:2004 LV:7.1.1 ,. ,.
I am using the lvwutil32.llb and have a problem with seeing all the vis that are in the llb. For instance in the winutil.llb there are about 20 vis and when I click on the block diagram I can't see them all (like the Extract Window Origin / Size.vi ) but if I download a vi that has it in it it doesn't seem to have a problem locating it or executing it. Any idea whats causing this or am I crazy?
Thanks, B-
| Ad |
Post
Aug 13 2008, 06:29 PM
Post
#2
![]() Extwemely Active Premium Member ![]() Posts: 1632 Joined: 23-January 05 From: Here Member No.: 1431 Using LabVIEW Since:2003 LV:8.6 ,7.0 ,.
QUOTE and when I click on the block diagram I can't see them all When you click on which block diagram? Did you try opening the LLB using File>>Open? Did you try placing it in user.lib and then looking in the palettes? -------------------- More than meets the eye...
Aug 25 2008, 10:11 PM
Post
#3
When you click on which block diagram? Did you try opening the LLB using File>>Open? Did you try placing it in user.lib and then looking in the palettes? I can see them from file>>open. They are placed in the user.lib and that is where I am having a hard time seeing all of them from the palettes.
Aug 26 2008, 04:17 PM
Post
#4
VIs in LLBs are displayed in the user.lib palettes only if they are marked as top level VIs. The VIs you want are not marked as top level. You can either change that by using the LLB editor (from the Tools menu, I think) or you can edit the palettes and add them manually.
| Time is now: 1st December 2008 - 07:34 PM |
