Tags
> Project Scanner
crelf
post Aug 11 2008, 11:33 PM
Post #1
I'm a LAVA, not a fighter.
V I Engineering, Inc.
Using LabVIEW Since:1993
LV:8.5 ,. ,.
Australia United States Nothing Selected My Blog
Description:
This toolkit will scan the active project for any SCC anomalies in the following categories:
- Files not in SCC
- Files not up to date (a newer version exists in SCC)
- Files not checked in
Additionally it checks if the following two things:
- Files are located under the lvproject folder
- Files that are in the dependency list but not under the LabVIEW executable folder
This toolkit uses the LabVIEW built in SCC VIs.
Instructions:
Unzip to a custom location, or install the OGP using VIPM (www.jkisoft.com/vipm).
To use the toolkit you have to call it from the menu of a LabVIEW window.
Submitter: Ton
File Version: 1.7.3
LabVIEW Version: 8.5.x
License: The BSD License
Admin Note: this LAVAcr submission has been moved from the submission queue to the Code Repository In-Development area due to inactivity timeout.
Attached File(s)
Attached File  Project_Scanner_1.7_3.zip ( 465.91K ) Number of downloads: 42
Tags
SCC
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Ton
post Aug 12 2008, 04:27 AM
Post #2
CCT It
Premium Member
Using LabVIEW Since:2001
LV:8.5.1 ,6.1 ,8.2.1
Netherlands hol_utrecht Nothing Selected My Blog My Gallery
QUOTE (crelf @ Aug 12 2008, 01:33 AM) *
Note from the author:
Thanks for putting this online while I had not the time to put development time in this tool. thumbup1.gif
I have some issues with my computer at this moment involving LabVIEW and other pieces of software.
This tool will get updates in the (near?) future. Don't hesitate to give feedback here.
Ton
Certified LabVIEW Developer
Shouldn't you be programming a Code Repository solution?
Tags
+Quote Post
crelf
post Aug 12 2008, 03:23 PM
Post #3
LV:8.5 ,. ,.
QUOTE (Ton @ Aug 12 2008, 12:27 AM) *
No problem - I had the choice of either putting it here or removing it from the queue entirely biggrin.gif so the choice was obvious...
Tags
+Quote Post
Yair
post Aug 12 2008, 06:15 PM
Post #4
Extwemely Active
Premium Member
Using LabVIEW Since:2003
LV:8.6 ,7.0 ,.
Israel Nothing Selected Nothing Selected
More than meets the eye...
Tags
+Quote Post
crelf
post Aug 12 2008, 07:04 PM
Post #5
LV:8.5 ,. ,.
QUOTE (Yair @ Aug 12 2008, 02:15 PM) *
Tags
+Quote Post
Time is now: 1st December 2008 - 11:10 PM
