Tags
> Related links
Visit our LabVIEW Wiki Hardware Portal
> Problems with Analog Output (NI-USB 6009)
ssteven121
post Jul 29 2008, 11:10 PM
Post #1
3 more posts to go!
Member
Using LabVIEW Since:2008
LV:8.20 ,. ,.
Nothing Selected Nothing Selected Nothing Selected
I'm trying to output an analog signal on an NI-USB 6009 DAQ device, but I keep getting error 200077 that says "Requested value is not a supported value for this property." Even though I'm wiring a constant (1V) into the write terminal, it's saying I'm inputting 10V (the device can only take 0-5V). Even with input of 0V it gives me the same error. When I use DAQ assistant, though, it works.
I've noticed some posts of a couple people having similar problems, but there's not a good answer. Any help would be appreciated,
S
Attached File(s)
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Karissap
post Jul 30 2008, 03:57 AM
Post #2
Member
Using LabVIEW Since:2005
LV:8.5 ,8.0.1 ,7.1.1
Australia Nothing Selected Nothing Selected
Try wiring 0 and 5 constants to the minimum value and maximum value inputs of the DAQmx Create Channel vi.
If this doesn't work you could use the "Generate NI-DAQmx code" feature from the daq assistant by right clicking on the express vi after you've configured it.
Test Engineer
Certified LabVIEW Architect(CLA)
Tags
+Quote Post
Ton
post Jul 30 2008, 07:59 AM
Post #3
CCT It
Premium Member
Using LabVIEW Since:2001
LV:8.5.1 ,6.1 ,8.2.1
Netherlands hol_utrecht Nothing Selected My Blog My Gallery
Do you use a Scale?
Ton
Certified LabVIEW Developer
Shouldn't you be programming a Code Repository solution?
Tags
+Quote Post
ssteven121
post Jul 30 2008, 07:55 PM
Post #4
3 more posts to go!
Member
LV:8.20 ,. ,.
Thanks for the help--it works! I changed the range from 0-5 and it solved the problem.
S
Tags
+Quote Post
Collapse
> Similar Topics
    Topic Title Replies Topic Starter Views Last Action
No New Posts 5 JackHamilton 1791 16th April 2004 - 09:54 PM
Last post by: JackHamilton
No New Posts   2 Michael_Aivaliotis 2366 6th June 2004 - 06:34 AM
Last post by: Michael_Aivaliotis
No New Posts   6 187063 2920 29th June 2004 - 12:50 AM
Last post by: 187063
No New Posts   3 JohnRH 1362 6th August 2004 - 04:42 PM
Last post by: todd
Time is now: 16th October 2008 - 08:26 PM
