> Related links
Tags
> Mouse Wheel Event in XControl, Is it possible?
LuPo
post Jul 25 2008, 12:01 AM
Post #1
I've come back for more.
Member
Using LabVIEW Since:2008
LV:8.5.1 ,7.1.1 ,.
Italy Nothing Selected Nothing Selected
I just want to do a simple XControl with a Labivew picture. The only feature I want to add is the possibility to use the mouse wheel to zoom the picture.
I have seen an example (http://forums.lavag.org/Mouse-Wheel-Scroll-Event-t148.html) where you can read the wheel status and behave accordingly but I think that example is not suitable for XControl because it requires a continuously running loop.
Any clue?
Tags
Go to the top of the page
+Quote Post
Ad
Post #
Tags
Quote Post
Ton
post Jul 25 2008, 05:59 AM
Post #2
CCT It
Premium Member
Using LabVIEW Since:2001
LV:8.5.1 ,6.1 ,8.2.1
Netherlands hol_utrecht Nothing Selected My Blog My Gallery
QUOTE (LuPo @ Jul 25 2008, 02:01 AM) *
Any clue?
Yes,
in your init ability load a VI dynamically, this dynamic VI runs continuously and checks the wheel mouse.
In the init state you also create a user event, this is fed to the dynamic VI, also create a dynamic event registration. This registers for the user event, and is linked to the event structure of the facade ability.
In the close ability you kill the dynamic VI, unregister the event registration and the user event.
Ton
Certified LabVIEW Developer
Shouldn't you be programming a Code Repository solution?
Tags
+Quote Post
LuPo
post Aug 24 2008, 06:41 PM
Post #3
Member
LV:8.5.1 ,7.1.1 ,.
QUOTE (Ton @ Jul 25 2008, 07:59 AM) *
Yes,
Ton
Thanks, that helps alot.
Tags
+Quote Post
Norm Kirchner
post Aug 25 2008, 02:54 AM
Post #4
Premium Member
Using LabVIEW Since:2000
LV:8.6 ,8.2.1 ,7.1.1
United States us_texas us_ohio My Gallery
QUOTE (Ton @ Jul 25 2008, 12:59 AM) *
Yes,
Something else you may decide to look into are the ActiveX callback functions.
You can actually wire a LabVIEW control reference into the reference node, but I don't know how this will work w/ XControls.
A very interesting segway into something very different.
I'll see what I can whip out if I get the chance.
Norman J. Kirchner Jr.
Automation Software Engineer
~,~ The Captain Was Here
Premium Blend
Tags
+Quote Post
Time is now: 4th December 2008 - 06:12 AM
